Charcoal Canister
Charcoal Canister
CJ11
157
95 SIDEKICK ON 31'S
Charcoal Canister
July 26, 2006, 07:17:45 PM »
Do you Know if this nedds to be on the engine took it off to do the belts hooked the 2 lines together. It seems to run fine for now any possible problems with this.
derekj
784
i'm the canadian guy eh?
Re: Charcoal Canister
July 26, 2006, 07:45:56 PM »
it will probably cause your check engine light to come on with an evap leak code. what it does is filter fumes from the gas tank before releasing them into the air. should not afect the way your vehicle runs.
derekj
91 Sidekick jx
2" BDS supension lift
2" BDS body lift
1" Coil spacers
32" TSL's and some other stuff I did And now with a Lockrite!
www.cardomain.com/memberpage/783382
