Idler Arm Brace
  • 1204 Views
Offline fullsink18
  • 250
  • Wheel Me!
Idler Arm Brace
« on: July 26, 2006, 06:02:21 AM »
Hey Guys, quick question.
Did anybody install the calmini idler arm brace?  When you take the nut off the idler arm there is also a lock washer and a big washer.  When you put the brace on did you reuse the big washer between the brace and arm or did you just use the brace to hold everything up?
« Last Edit: July 26, 2006, 06:05:19 AM by fullsink18 »
94 2dr kick 8v
-     Full set of Calmini's skid plates, calmini header and full exhaust, k&n filter, sky idler arm, calmini idler arm brace and truss with stabalizer, lock-rite rear locker, Calmini 3"  BL, 2" Digger Spacers, Shrockworks bumper, chicago electric 8,000lb winch, 31" Grabber AT2, 15x7 2
Offline derekj
  • 784
  • i'm the canadian guy eh?
Re: Idler Arm Brace
« Reply #1 on: July 26, 2006, 10:16:07 PM »
i made my own idler brace and if i remember correctly i only used the lock washer as the brace takes the place of the big washer.
derek
91 Sidekick jx
2" BDS supension lift
2" BDS body lift
1" Coil spacers
Offline fullsink18
  • 250
  • Wheel Me!
Re: Idler Arm Brace
« Reply #2 on: July 27, 2006, 05:45:04 AM »
Thanks, Yeah I am thinking of taking the washer out becuase that brace should hold it up and then the nut would be threaded on better.
94 2dr kick 8v
