shifter problem - need help
Ralph47
2
I Love ZUKIWORLD!
July 24, 2006, 07:48:26 PM »
I have a Samurai that ran and shifted perfectly. I put the trans in 2nd, and the transfer case in N per the owners' manual, and towed it 20 miles home. When I tried to drive it, I moved the lever from N to 4wd, and it stuck somewhere in between and won't be budged. The lever will not shift at all. The front driveshaft is turning but I'n unable to move forward or back.  I took out the transfer case shifter and got the forks to line up, put shifter in and it worked for a few shifts then locked up again.  Is the shifter sheet the knob that goes into forks at the bottom of shifter?  Where do I get a replacement?
Last Edit: July 24, 2006, 07:57:21 PM by Ralph47
dsumers
72
Re: shifter problem - need help
July 24, 2006, 08:26:14 PM »
The shifter sheet looks like a o-ring seal, with the shifter removed, look inside and you will see it. You will need a pick to reach down there and pull it out. Most all venders like trail tough carry these on hand.
Ralph47
2
I Love ZUKIWORLD!
July 24, 2006, 09:05:41 PM »
Thank you. I am a new owner, can you tell me where trail tough?
Drone637
8121
116
Evil Cow
Reply #3 on:
July 25, 2006, 09:34:34 AM »
http://www.trailtough.com/
I like Hawk Suzuki Parts myself, as they usually have parts for my SJ-410.
http://www.hawksuzukiparts.com
There is a pretty good list of Suzuki Aftermarket Companies at Izook (
http://www.izook.com/
) down the left hand side of the screen.
