Reming Camber
  • 10 Replies
  • 1983 Views
Offline TysonS
  • 383
  • www.funinbc.com
Reming Camber
« on: July 23, 2006, 03:30:33 PM »
I have heard of people reeming out the upper or lower strut hole to bring there camber back and im wondering if it is better to reem the lower or upper hole?  thanks
Offline TN_Tracker
  • 1113
    • TN Tracker's Suzuki Space
Re: Reming Camber
« Reply #1 on: July 23, 2006, 04:36:55 PM »
The upper hole I would think. That's where the instructions for my camber bolts said to put them.
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
Re: Reming Camber
« Reply #2 on: July 23, 2006, 06:38:03 PM »
If you ream the hole out bigger and don't do anything else to hold the bolt, it will slide out of adjustment not matter how tight you tighten it. If you want to try the reaming idea, ream out the upper hole in the strut, not the spindle, then use two big thick washers, one on each side. Once you have the camber set right, weld the washers to the strut bracket so they can't move.
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
Re: Reming Camber
« Reply #3 on: July 23, 2006, 07:14:59 PM »
BRILLIANT!
And that, folks, is why Forums like this one are so great!
Thanks, Digger!
Ack
Offline da_tub
  • 307
Re: Reming Camber
« Reply #4 on: July 23, 2006, 07:56:46 PM »
orrrrrr spend the whoping 10 to 15 bucks and get camber bolts..lol  but diggers idea works to...
91 four door ,and some stuff
Offline Digger
  • 1991
Re: Reming Camber
« Reply #5 on: July 23, 2006, 08:35:54 PM »
For the record, both my rigs have camber bolts... ;)
Offline TysonS
  • 383
  • www.funinbc.com
Re: Reming Camber
« Reply #6 on: July 23, 2006, 10:30:33 PM »
where is a cheap place to get camber bolts?  Canadian tire? Lordco? Napa? Wallys crappy World?
Offline ack
  • 1659
    • Ack's FAQ
Re: Reming Camber
« Reply #7 on: July 24, 2006, 02:59:30 AM »
Just about any auto parts store can get you camber bolts.  They are $15-20 US a set.  They cross to a number of vehicles so they should be easy to get. They may not have them in local stock, but they should have them in the warehouse nearby. I got mine at O'Reillys.
Ack
Offline da_tub
  • 307
Re: Reming Camber
« Reply #8 on: July 24, 2006, 04:41:29 PM »
or any tire shop that does wheel alignments should have them also
Offline Agent Orange
  • 711
    • Trying to learn
Re: Reming Camber
« Reply #9 on: July 24, 2006, 05:58:33 PM »
tysons,
go to lordco and order this brand and part number. don't be cheap a penny saved always winds up being a dollar spent. i bought mine at lordco, and they work great, i've had them in for a couple of years now.
http://www.specprod.com/PROD_DIR/C_PROD_passcar_SEARCH_DYN.cfm?cmd=Cam&cmd2=81250&cmd3=
sapien
Re: Reming Camber
« Reply #10 on: July 24, 2006, 08:31:39 PM »
^ seen those on EBay about $25 shipped.  search for 81250
