Sammy Questions
  • 1210 Views
Offline Sami86
  • 41
Sammy Questions
« on: July 23, 2006, 12:01:33 AM »
ok i went crawling to day and was having a bit of what i think was vapor lock..... i got at a/or about a 45 degree angle and it would start running really ruff..... i mean idle was ok.... but give it gas and it wouldnt go over 2000 RPM and put out. but when i was sitting level all was ok....so how do i prevent this in the future.... and no get a 1.6 or FI ranting so plz help......
1986 Samurai stock drivetrail, 2" shackle lift 30" tires..
Offline Sami86
  • 41
Re: Sammy Questions
« Reply #1 on: July 23, 2006, 11:55:55 AM »
please anybody?
Offline locjaw
  • 2045
  • 22
Re: Sammy Questions
« Reply #2 on: July 23, 2006, 12:07:19 PM »
do you have a stock or aftermarket carb?
that info would help
jason
Offline Sami86
  • 41
Re: Sammy Questions
« Reply #3 on: July 23, 2006, 01:28:47 PM »
its the stock carb....
Offline Sami86
  • 41
Re: Sammy Questions
« Reply #4 on: July 24, 2006, 10:43:30 AM »
anyboby??
Offline john1974
  • 617
  • http://zuknation.net
    • Zuknation
Re: Sammy Questions
« Reply #5 on: July 24, 2006, 10:56:14 AM »
was it stalling out? fuel mixture could be off, check front window on carb to see fuel level.  if u cant see it when truck is at idle, take a needle nose and while your looking at the window pinch off the fuel line going into carb, if u see the fuel level start to come down your float is stuck open.
maybe a vac line leak too, check around all the lines. make sure there all good.
