Well your fluid is going into somthing,
the Calipers stay close, so that isn't it.
I had this problem once, I replaced the
brake shoes and did a good cleaning and
adjusting on the slack adjusters, I get good
pedal feel, even on 33" Swampers, I can lock
em up in one push.
Like I said, you need to adjust the rears until
they are dragging on the drums, you might even
go until they get hard to turn, unless you have
a bad master, but I wonder why a coupple of
pumps gives you good pedal, I would expect
there to be a leak down if the Master were bad,
and the booster just gives you power, not pedal,
you would have a feel like the engine were off if
the booster were bad, unless you have some wierd
crap going on, this is where I would look
Good Hunting
