97 SideKick 1800 into 96 SideKick 1600?
  • 1385 Views
Offline ToyYoda
  • 226
« on: June 25, 2006, 01:12:25 PM »
I have a "Blown"1600 16V motor on my 96 SideKick 4x. Over the weekend I found a 97 1800 twin cam SideKick 4x. The 97 Kick. was hit in the front but all power train is fine. Who know what fits what? Love to bolt in the 1800 if it can be done. Thanx
Offline cj
  • 1276
  • I drive a really big ATV
Re: 97 SideKick 1800 into 96 SideKick 1600?
« Reply #1 on: June 25, 2006, 03:54:59 PM »
The 1.8 is the same as the 2.0 so if you do a search you should find what is required to swap it in as it has been discussed.
« Reply #2 on: June 26, 2006, 05:06:23 AM »
Is it? IIRC Eric fitted a 1.8 into a 1.6 without too many problems. The 2ltr needs a custom flywheel.
Edit: From previous thread:
Are you sure? I've bolted a 1.8 DOHC which is essentially the same as a 2.0 DOHC to a 1.6 transmission. It was a direct bolt up. Same clutch was used (cable actuated from the 1.6 transmission).
« Last Edit: June 26, 2006, 09:58:57 AM by Rhinoman »
Offline ToyYoda
  • 226
« Reply #3 on: June 27, 2006, 08:20:04 AM »
How do I find IIRC Eric for this info?
« Reply #4 on: June 27, 2006, 11:00:55 AM »
He'll be along soon I should think or you can click on his name in the thread and then send him a PM.
Offline ToyYoda
  • 226
« Reply #5 on: June 27, 2006, 12:20:41 PM »
Thanx Rhinoman, I know I said SideKick But it's a X 90. Should be the same I hope, Just every other place I ask for stuff they say X-what? I Should know better now that I'm on ZUKIWORLD !
« Last Edit: June 27, 2006, 12:35:53 PM by ToyYoda »
