Can you use a cone filter on a 16V
  • 19 Replies
  • 2892 Views
Offline CJ11
  • 157
  • 95 SIDEKICK ON 31'S
« on: June 24, 2006, 06:30:44 PM »
I had a couple of diff air intake set-ups on my 8v kick. but my 16V has two sensors a mass airflow and air temp will the cone filter mess  with anything or should I just get a K&N put it in the box and forget about it. If any one has pics of 16V with cone filter send them my way..
Re: Can you use a cone filter on a 16V
« Reply #1 on: June 24, 2006, 07:08:38 PM »
There are a couple shots in the archive of people using a cone filter with the 16V, I can't find them at the moment though.
I ended up just going with a standard K&N to avoid water splash damage to the engine.  :)
Offline droppedtracker
  • 238
  • its a tracker thing, you wouldnt understand!!!
« Reply #2 on: June 24, 2006, 10:43:20 PM »
heres a pic of my old 98 tracker with calmini header and cone filter...
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #3 on: June 25, 2006, 06:28:30 AM »
Do a search, we've discussed this several times.
Offline CJ11
  • 157
« Reply #4 on: June 25, 2006, 08:55:06 AM »
Did a search did not come up with much i'll just give it hell and see what comes up any other help or info would be great thanks
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #5 on: June 25, 2006, 08:58:02 AM »
Do a search for cone filter and my name.  It was discussed less than a month ago and I did my setup about 3 months ago.  I can also think of three of us with similar setups off of the top of my head.
HINT: Check out my CarDomain site.
Offline CJ11
  • 157
« Reply #6 on: June 25, 2006, 09:00:09 AM »
One more thing is there to much HOT air getting sucked into the cone since it is the engine compartment and not sucking fresh air from out side
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #7 on: June 25, 2006, 09:02:12 AM »
Some will tell you it's too much hot air but honestly I don't think so.  I left the ducting that runs up on the fender well in place so it's shooting cold air at the filter and meanwhile the filter is sucking in LOTS more air than the stock setup does.  Yes, it's hot/warm air but it's a much larger quantity of air.
Offline CJ11
  • 157
« Reply #8 on: June 25, 2006, 09:03:26 AM »
hey AJM is it worth the time to do this mod i saw your post it looks easy enough no negitives to doing if not what the hell..
Offline CJ11
  • 157
« Reply #9 on: June 25, 2006, 09:06:24 AM »
Once it stops raining I will get started i will post some info on how it went and how it works thanks for your help
Offline Carnage
  • 2453
« Reply #10 on: June 25, 2006, 09:59:57 AM »
did you get my PM?
I sent it to you as soon as you posted this query
Offline Jookycola
  • 372
« Reply #11 on: June 25, 2006, 11:49:41 AM »
The best all around setup for this (as to avoid water from rain or heavy off-roading to damage engine, as well as a great location for the filter to suck in cooler air.)
Buy the K&N drop in filter.
take out the bottom bucket from the air box.
take a hole saw and cut into any side of the bottom bucket.
then take a jigsaw and cut out the whole side, then do the same on the next side....continue doing this till all 4 walls of the bucket are cut out and all that is left are tha 4 corners (for support)
bolt the bottom bucket back into it's position on the fender.
drop in the K&N
close the top part of the air box back up
.....and ta-da, intake.
no monkeying around with the MAF or 02 sensors or anything....it's all stock.
  [/url]
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #12 on: June 25, 2006, 11:56:17 AM »
drop in the K&N
I guess I'm missing something...how would that stop water from getting to the filter?  Sounds like you just completely opened up the bottom of the box. ???
Offline Carnage
  • 2453
« Reply #13 on: June 25, 2006, 11:58:01 AM »
personally I wouldnt call it the best (imho)
but its def one way to do it
(i think i have that way listed down somewhere)
=D
Offline fallguy
  • 127
« Reply #14 on: June 25, 2006, 04:39:34 PM »
does anny one make a snorkel for the trackkicks wouldent that be the best of both worlds
