e-brake light?
  • 10 Replies
  • 1781 Views
Offline sidekick101
  • 128
  • best site on the net
e-brake light?
« on: June 21, 2006, 06:58:28 PM »
turns on whne i go aorund corners but once i get around them it its off? any ides? loose wire maby?
1993 sidekick JX, 2 dr, soft top, automatic,
Offline Quaddawg
  • 1622
    • My Ebay Store
Re: e-brake light?
« Reply #1 on: June 21, 2006, 07:19:47 PM »
 It is also an ABS malfunction light on Kicks so equipped.
Offline 4njeep
  • 113
  • I Love ZUKIWORLD!!!!
Re: e-brake light?
« Reply #2 on: June 21, 2006, 07:51:52 PM »
maybe check your brake fluid level.
92 sidekick jlx auto
2" suspension lift
5.13 gears, locked rear.
30x9.5 goodyear mt/r's on CSA Scorpion's
Offline da_tub
  • 307
Re: e-brake light?
« Reply #3 on: June 21, 2006, 08:03:15 PM »
x2 on the fluid level, mine did the same thing,, added fluid, and who'd thunk it it went away..
91 four door ,and some stuff
Offline takai
  • 907
Re: e-brake light?
« Reply #4 on: June 21, 2006, 08:16:01 PM »
I would have to go with checking the fluid as well.
'Cause, I am to misbehave.
Offline fullsink18
  • 250
  • Wheel Me!
Re: e-brake light?
« Reply #5 on: June 22, 2006, 05:28:34 AM »
Mine was doing the samething.  I ended up tighting the snail adjuster on the rear drum brakes.  When I did that i found out my wheel cylinder (applies pressure to pads so they hit the drum and slow you down) was shot.  But replaced it and tightened the the rear brakes and it went away.
94 2dr kick 8v
-     Full set of Calmini's skid plates, calmini header and full exhaust, k&n filter, sky idler arm, calmini idler arm brace and truss with stabalizer, lock-rite rear locker, Calmini 3"  BL, 2" Digger Spacers, Shrockworks bumper, chicago electric 8,000lb winch, 31" Grabber AT2, 15x7 2
Offline pcguy
  • 343
  • 1996 Tracker 4x4
Re: e-brake light?
« Reply #6 on: June 23, 2006, 01:56:10 AM »
x2 on the rear wheel cylinders
Offline Speedracer7c
  • 2210
Re: e-brake light?
« Reply #7 on: June 23, 2006, 07:52:57 PM »
Wouldnt be wheel cylinders of its only on corners. The brake fluid level is the answer.
Offline 4njeep
  • 113
Re: e-brake light?
« Reply #8 on: June 24, 2006, 01:01:50 AM »
Yeah. but the wheel cylinders could be the cause of the low brake fluid. maybe everything is gettin to warn and the the rear wheel cylinders are leaking.
let us know if you find out the problem.
2" suspension lift
Offline sidekick101
  • 128
Re: e-brake light?
« Reply #9 on: June 27, 2006, 01:41:54 PM »
well added the fluid and it stop.. but i went to the drive in last nihgt and discoverd that the ebrake doesn't alweasy work properly. when u pull it it turns your head lights off. but it only worked 1 outta 3 times. any input>?
Offline da_tub
  • 307
Re: e-brake light?
« Reply #10 on: June 27, 2006, 01:54:27 PM »
if u take the center console  off theres a little switch on the side of the e brake handle.. somtimes they get a little gummy . try cleanning it up and re greesing it up,, with die electric greese... should free it up and work again( ;)
