sammy ecu smokes
sammy ecu smokes
brawnyrebel
131
i've cought a case of samuraitis
sammy ecu smokes
February 07, 2005, 08:56:04 AM »
My friends samurai ecu started smoking the other day, pretty bad too. He hooked up a known good ecu and it also smoked. Does any one have any ideas what might cause this
If its not broken, break it
mrfuelish
2862
13
you must have a perception problem.
Re: sammy ecu smokes
February 07, 2005, 08:58:20 AM »
open it up and see what fried,try following it back to the plug and then see what the color code is on the wire and go from there.
1987,1988,1988,1990 samurai's, 1953 m38a1, 1996 x-90,blue.1996 x-90 red.1994 2 door tracker. only Dead Fish go with the flow. No Hairy Nosed Wombats were ran over on the trail today. My ZUK is Xenophobic.
zookaholic
387
"asphalt was created so yuppies could go 4 wheelin
February 07, 2005, 08:59:11 AM »
if the ecu does not match its gooing to smoke like shit! theres something u can do but i forget to stop that!
1987 Samurai, neon green, 1.3 stocker, 6.4:1 trail tough tranfercase, spoa, warn 8000, 34" swampers
1988 samurai (project, on blocks)
Rhinoman
4502
36
Bend it, Break it, Fix it
Reply #3 on:
February 07, 2005, 11:03:22 PM »
Most likely a short circuit somewhere
http://www.rhinopower.org
wildgoody
8134
67
Reply #4 on:
February 08, 2005, 02:02:56 AM »
Try the patch, it seems to help to quit
smoking, besides, it's a bad and expensive
habit.
On a more serious note, that was an expensive
test !!! I would look into the wiring very closly
before trying another ECU in that vehicle
