broken axels
  • 17 Replies
  • 3795 Views
Offline msabmf
  • 20
broken axels
« on: June 19, 2006, 08:26:00 PM »
does any body sell upgrded axel shafts for stock sammy housing besides calmini i break  theres about every 3rd trail i do              THANKS !!!!!!!!!
88 sammy 14"lift 36" tsl irocs locked very custom full exo cage spring over with 3"bonz eye springs custom rockers custom h2 tire carrier
Re: broken axels
« Reply #1 on: June 19, 2006, 09:19:51 PM »
spider trax full floaters would be the next Better thing, then trail toughs or skys toyota off set rear ends.
Offline Maroon Monsoon
  • 876
Re: broken axels
« Reply #2 on: June 19, 2006, 10:45:57 PM »
do D 44's or a 9 inch or something. if you break your shafts that often get something where you can run a 31 spline axle shaft and a good strong ring, pinion and spider gears.
no use messing around with light stuff if it breaks all the time. if you have leafs it should be moderately easy to weld some perches on some new axles and bolt em on
Offline zukzilla1662
  • 90
Re: broken axels
« Reply #3 on: June 20, 2006, 08:56:01 AM »
how much wider are dana 44 and the 9 rear?
Offline msabmf
  • 20
Re: broken axels
« Reply #4 on: June 20, 2006, 08:21:20 PM »
im installing 44s and 4 link this winter but i still want to wheel the rest of the summer so i need axels  till then   thank for the replies though
Offline joe_and_jeep
  • Why have a Rev Limiter and not use it?
Re: broken axels
« Reply #5 on: June 20, 2006, 08:25:21 PM »
If you get a Quadra Trac Jeep Wagoneer (Pre 1980) It will come with a passenger drop D44 and rear passenger drop D44 perfect for the offset in the Sammi case.  Can go down to 5.38 gears and they are roughly 58inches wide.  Ring and pinion are a lot bigger and the shafts are 30spline.
96 Tracker DD - 2in, 30s
95 Tracker Under the Knife - 4.3V6 - Rest Unknown
91 Jeep YJ Full Cage, Tri Link, D44/D44 35s
84 Jeep XJ Doubler HP44/9IN 35s
Offline 1bigtracker
  • 3409
Re: broken axels
« Reply #6 on: June 21, 2006, 04:58:19 AM »
you will keep breaking them then if you already had aftermarket axle shafts.
I can't see blowing the money on a full floater just to swap it out in a few months :-\  unles you want to send it to me after your done.(6in wider than stock plz ;D )
Stu
Offline the_maplebar
  • 466
Re: broken axels
« Reply #7 on: June 21, 2006, 08:47:33 AM »
How strong are the axles that come with the Newfields?
http://www.cvunlimited.com/NEWFIELD/suzuki.htm
Offline SnoFalls
  • 1358
Re: broken axels
« Reply #8 on: June 21, 2006, 10:06:08 AM »
Actually can go to 5.89's, and the front is 60.5" WMS (I forgot the rear ... it might be 58")
  • 90
Re: broken axels
« Reply #9 on: June 23, 2006, 06:38:43 AM »
how much wider ar 44 and 9 inch rear on my samurai, how much would the tires stick out gotta keep mine street legal
  • 876
Re: broken axels
« Reply #10 on: June 24, 2006, 03:49:30 PM »
a friend of mine has a 9 inch on his leaf sprung wrangler and he matched it up to his front axle pretty nicely. I don't know if he narrowed it or what vehicle it was off of. if you narrow the axles it gets way spendy for shafts I heard. there is a writeup on a 9 inch in a track/kick and it's off an old bronco and only about 3 inches wider than the front end of that kick if I remember right.
I have no idea avout the 44's. you could always get a narrow offset wheel so the tires wouldn't stick out too bad.. would only work to a point but you know
Re: broken axels
« Reply #11 on: June 24, 2006, 07:15:25 PM »
What sized tires are being run that you keep snapping axel shafts?
  • 876
Re: broken axels
« Reply #12 on: June 25, 2006, 12:16:36 AM »
a friend of mine always raves about his stupid nissan axles and how they are as strong as dana 60's... we always talk about NAS (nissan axle swap) and ask why people don't NAS F-350's so they can have a beefier axle just to piss him off cause he is full of crap
Offline msabmf
  • 20
Re: broken axels
« Reply #13 on: June 26, 2006, 07:12:16 PM »
im running 14" lift with 36" iroks and a detroit locker in the rear and a lincoln locker in front
i have never had an issue in the front i only brake the rear short side shaft
thanks fo the info on the jeep axels i will check to see if the off set will be equall side to side
Offline msabmf
  • 20
Re: broken axels
« Reply #14 on: June 26, 2006, 07:14:12 PM »
thats funny my daily driver is an 06 f250 4x4 diesel 4 door short bed its on 37s my sammys only 2" shorter
« Last Edit: June 26, 2006, 07:15:56 PM by msabmf »
