help me with my turnsignals.
  • 1111 Views
Offline hman1991
  • 53
« on: June 16, 2006, 10:07:48 PM »
Ok i read my search results without any exact results. heres the problem. i used the trailer conversion harness and the 3 wire round lights. my turnsignals work fine with tail lights on or off, but as soon as i aply the break the flash faster. now i thought i read somwere b4 about a resistor or something. i really want to fix this. i have my tracker and sammy done both with same problem. Oh and these r not the LED lights.
Offline derekj
  • 784
  • i'm the canadian guy eh?
Re: help me with my turnsignals.
« Reply #1 on: June 16, 2006, 10:17:25 PM »
check your grounds and you may have to put in a heavy duty flasher also.
derek
91 Sidekick jx
2" BDS supension lift
2" BDS body lift
1" Coil spacers
Offline hman1991
  • 53
Re: help me with my turnsignals. Fixed with resistors!
« Reply #2 on: June 20, 2006, 09:23:51 PM »
i fixed it i fooled my truck by adding 2 resistors b4 the conversion harness make it think it has taillight hooked up ant the actual tailights are trailer lights. i used 20 watt 8 ohlm resisters from radioshack
