Tracker vs Sidekick grill
  • 11 Replies
  • 4281 Views
Offline dwcrisp
  • 212
  • 98 Tracker 2dr, 1 1/2" spacer lift, 30X9.5 BFG MTs
« on: February 05, 2005, 02:36:03 PM »
I have a 98 Tracker 2dr softee.  I HATE THE GRILL!
Would a 98 Sidekick grill be a direct bolt on replacement?
My 98 bolts on with one center bolt and that is all.  I wonder if the Sidekick is the same?
anyone tried it?
Re: Tracker vs Sidekick grill
« Reply #1 on: February 05, 2005, 02:49:00 PM »
Should be a streight swap.
I could be wrong.
« Reply #2 on: February 05, 2005, 04:09:20 PM »
There should be 5 screws, one center,
two low by the headlights, and 2 in each
fender on the earlier ones that wrap around
the bottom leading edge on the front fenders
Offline dwcrisp
  • 212
« Reply #3 on: February 06, 2005, 01:29:37 AM »
On mine (98 tracker 2dr) when I was doing my lift kit I found that there was only one center bolt and the grill snapped out from there without difficulty.  There were no other bolt holes so I am assuming it is only a simple one bolt snap in mount.  If a 98 Sidekick is exactly the same it would be great.  If the dimmensions are exactly the same even if it is a 5 bolt mounting system that would work as I could just screw in additional bolts as needed.  If the shape is way off it might not work.  I noticied on one side the outside edge of the grill locks into the air intake in the fender well.  That could be a factor also.
Anyone tried this?
Offline droppedtracker
  • 238
  • its a tracker thing, you wouldnt understand!!!
« Reply #4 on: February 06, 2005, 04:21:48 AM »
i have a 98 tracker my grile has 1 bolt in the center of the grille but also has 8 plastic clips that the grille snaps into forget the sidekick grille just do what im going to do and thats putting a phantom grille on!!!!!!!!!!!!!!! ;D
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #5 on: February 06, 2005, 01:03:12 PM »
I cant picture what the 98 sidekick grill looks like but I have a 97 tracker and I swapped a 94 4 door grill in mine. You would need the bumper also in that case. The grill has a lower lip that the tracker does not. Do you have a pic of the grill you want to install?
Mike
Offline dwcrisp
  • 212
« Reply #6 on: February 06, 2005, 01:56:10 PM »
mikerpm4X4,  the 98 and 97 are the same grill on a tracker.  An older model with a lower lip as you describe might be a neat swap since I have a gap now that I did a lift (2") and the lip from an older model grill might just be the cool ticket.   how does the older model grill mount?  Did it fit the opening?
mudfkr
« Reply #7 on: February 06, 2005, 07:26:35 PM »
I think you'll find the lip sticks out like this
and not down so it wouldn't cover the gap from your body lift.
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #8 on: February 07, 2005, 09:06:11 AM »
It does fit the opening but I had to drill the upper center hole in a different place. Honestly I cant remember what else I did? :-/ Sorry. I know it can be done... ::)
Mike
Offline dwcrisp
  • 212
« Reply #9 on: February 07, 2005, 11:57:57 AM »
So it does fit the housings around the lights and into the general opening.   I see what you mean.  If it didnt look right I bet I could grind it down flat if I needed to.
Offline whitfield
  • 633
  • 4-dr Kick on 34's
« Reply #10 on: February 07, 2005, 04:43:12 PM »
THis is my 1998 Sidekick Grill in my 1994 Sidekick.
Nothing special, no mods.   Just used the center screw and the 2 sides under the fender edge.
My tracker grill looks different.
« Reply #11 on: February 08, 2005, 05:10:48 PM »
That looks wicked whitfield;D
