31x10.5 R15 BFG MUD TERRIANS on the GV
  • 15 Replies
  • 3431 Views
Offline JDMCRX
  • 1110
  • 02 Grand Vitra Pimp lol
« on: June 14, 2006, 09:41:09 PM »
Hey guys. Just in a debate. I need new tires the AT the rears are bald i love them in the snow im gonna keep them for winter. Im thinking of going 31x10.5 R15 Mud terrrians. Im just curious hows the gas millage and shit?? Also im gonna slap the 2" RR body lift so they should not rub.
01 GRAND VITARA
Offline beerman
  • 339
  • Suzuki 4x4 Norway
    • www.tristania.com
Re: 31x10.5 R15 BFG MUD TERRIANS on the GV
« Reply #1 on: June 15, 2006, 05:09:04 AM »
if your GV has 16" rims stock, like mine, you must remove the front calipers to get the rims on >:(
-and i guess you'r gas mileage will suffer...
Offline the_maplebar
  • 466
« Reply #2 on: June 15, 2006, 07:53:05 AM »
If you run wheel spacers and maybe clearence the calipers a little they will fit.  But JDMCRX already knows that ;)  Also the Tracker/Vitara calipers (like I have)  are a little smaller and can handle some 15's ;)
Since I am only running 29's can't really help you with how the 31's will affect you.  I love the STT's and I'm so glad I didn't settle for an AT  ;D  (Thanks AJMBLAZER for that decision  ;))
Offline bzzr2
  • 1011
« Reply #3 on: June 15, 2006, 08:09:21 AM »
swampers josh, swampers................. super swampers......  Three Stage Lugs........   oh ya!
09 taco reg cab short box 4x4
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #4 on: June 15, 2006, 08:56:31 PM »
With modern tire designs the loss in mpg and power by going to a MT over a AT is minimal.  Just get some MT's and sipe 'em.  Bet you never run those AT's again.
Offline r3cc0s
  • 321
« Reply #5 on: June 16, 2006, 10:54:21 AM »
When I get my lift from you Josh, I will be running center siped 245/75/16" Goodyear MT/R
30.6 Diameter
I think the goodyear MTR is perhaps the best inbetween tire for mud/AT as long as it's siped. For such a light truck as ours, the tread life should be good, even though they use the very soft silicone based tread.
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #6 on: June 16, 2006, 06:56:30 PM »
I have to say I haven't seen or heard much good about the MT/R in the mud.
Offline JDMCRX
  • 1110
« Reply #7 on: June 16, 2006, 09:35:54 PM »
hey sorry about the lift i should have them done soon. Just been busy with the house and moving stuff
Josh
30.6 Diameter
01 GRAND VITARA
Offline r3cc0s
  • 321
« Reply #8 on: June 17, 2006, 09:30:31 AM »
I think it's all subjective... 4 wheeler rated the MT/R quite well only behind the super swampers in their all out mud tests
however... IMO the only true mud tires are the swampers...
Mud-Terrains/MT/R/Baja Claws/Mud Rovers are all great off-road tires, but not good enough to deal with thick mud or clay. Only TSL's or better yet "Boggers" have I seen acctuality do the job with ease (at least for a DOT rated tire)
However... I like the MT/R's as their snow performance is superior than other MT designs due to their lug patten and much softer tread. Add some center lug siping, and I found that they performed better than a set of BFG AT's in the worst winter weather conditions.
Offline JDMCRX
  • 1110
« Reply #9 on: June 17, 2006, 11:05:43 PM »
I looked at the TSL the side lug is huge and i dunno i do not wanna chop the truck up that bad
01 GRAND VITARA
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #10 on: June 18, 2006, 07:26:45 AM »
Just get some good radial muds.  A TSL Radial sounds a bit extreme for what you want to do.  If you want something in the Swamper vein try the Interco TrXus MT's.  Got 'em on the Ranger and love them.  A more civilized Swamper but still with some nice lugs.
Offline JDMCRX
  • 1110
« Reply #11 on: June 18, 2006, 10:19:48 AM »
I think ill be going the MT BFG later after i move my house and get these lifts cut for you guys that my first priority
Josh
01 GRAND VITARA
Offline bzzr2
  • 1011
« Reply #12 on: June 19, 2006, 07:12:28 AM »
you already know that my truck is too light to pull you outta the mud...   i'm going with 31x9.5's  dont expect anything will need cutting/chopping/trimming anywhere.  i better not!
Offline JDMCRX
  • 1110
« Reply #13 on: June 19, 2006, 10:47:19 PM »
I dunno ur 30's looked like u had more room then my 29's lol
01 GRAND VITARA
Offline bzzr2
  • 1011
« Reply #14 on: June 20, 2006, 08:10:20 AM »
maybe, they're so close in size it's hard to tell,  check this link http://www.zukiworld.com/forum/index.php?topic=12560.0  another factor is also that i will be sticking with my stock 6inch wide wheels for now so things will be inside the fenders.
