fitting the base was easy, the remote face was not to bad
i drilled a small hole in the top right hand side of the space so that when the unit is removed you will not see the hole and only big enouph for plug to go through.
note: the gap behined the pocket is only 8 mm
once fitted i used double side tape to stick face in spot to keep the clean look...
and hand unit just fits when door is closed.
