speedo cable
  • 10 Replies
  • 2229 Views
Offline ibhuktonfoniks
  • 43
speedo cable
« on: June 13, 2006, 10:19:37 AM »
can you grease the speedo cable on a 92 kick like on older cars?
Offline Yoak
  • 577
Re: speedo cable
« Reply #1 on: June 13, 2006, 02:58:32 PM »
It is a standard cable, similar to what I have on my 72 datsun so I don't see why not.
Cable tech dosen't seem to have progressed to much  :P
  • 43
Re: speedo cable
« Reply #2 on: June 13, 2006, 07:47:24 PM »
i took dash cluster out and could not get the worm out of the outer cable housing. ???
Offline Yoak
  • 577
Re: speedo cable
« Reply #3 on: June 13, 2006, 07:52:48 PM »
Pull  ::)
  • 43
Re: speedo cable
« Reply #4 on: June 13, 2006, 08:14:55 PM »
 :Di did with pliers ive seen several posts of replacements but none on greasing have you ever had yours out?
Offline Yoak
  • 577
Re: speedo cable
« Reply #5 on: June 13, 2006, 09:40:06 PM »
I replaced mine a few years back, so yep ive ad mine out.
PM me if needed
  • 43
Re: speedo cable
« Reply #6 on: June 14, 2006, 05:42:56 AM »
i may be confused  ::) it wouldent be the first time :D you got the inside worm part of the cable pulled out of its outer casing part of the cable just by pulling on the inner part? from the top or the bottom? i tryied from the dash side.
Offline Yoak
  • 577
Re: speedo cable
« Reply #7 on: June 14, 2006, 08:31:24 AM »
It should have some play in it, now you've got me a bit confussed lol.
I will ahve to look at mine, and sadly mine is out on a project for the indeffinate future.
My other car (Datsun) you can pull it out as far as you want....at the risk of not getting it back in.
Has the cable been giving you any problems?
Why do you feel you need to grease it?
MY only broke as I put a sharp angle in the line after taking the cluster out...then I had to replace it lol
  • 43
Re: speedo cable
« Reply #8 on: June 14, 2006, 10:48:08 AM »
squeaking bad gets on my nerves BAD >:( ive had to grease the one on my 52 ford earlier this year for the same thing . on it just unhook from speedo and pull the inside out rub with vasoline slide back in rehook bam good to go. but i couldnt get this ones inside out. ???
Offline Yoak
  • 577
Re: speedo cable
« Reply #9 on: June 15, 2006, 02:06:49 AM »
Gett a brand new one, my was less than 40
Offline AJMBLAZER
  • 2166
  • Your mom.
Re: speedo cable
« Reply #10 on: June 15, 2006, 03:47:59 AM »
I agree with him, I got mine for my '96 (which is a bit$% to remove thanks to the new dash) from the local Chevy dealer for $45.  Relatively cheap and hey, for some cussing and scraped up hands it fixed the problem permanent.
Word of advice, skip the parts store cables as they're universal and also you might want to fire a little lube down the cable when you first install it.  A cable for a Geo Tracker might have been sitting on the shelf for years so the grease has set or moved within the cable.  Mine squeaked a bit at first and then it started to go away.  I shot some old "household oil" I inherited from my grandfather down the cable and haven't heard a noise since. 8)
