sammy tranny problems need help
  • 1245 Views
Offline boscosfire
  • 14
  • Sammy Crazy
« on: June 10, 2006, 06:52:50 PM »
I just got my 86 sammy and the tranny is stuck in 3 or 4th gear not sure. The weard thing is it will move when the shifter is in nuetral, if i put the shifter in any gear it locks up. anybody have any idea what is wrong.
Offline mverley
  • 652
  • 20
  • SPACE JUNK
Re: sammy tranny problems need help
« Reply #1 on: June 11, 2006, 01:41:34 PM »
I've rebuilt 3 sammy trannies now...so I'm no expert, but I've seen the workings of them a few times.  My guess is bent shift forks.  No matter what it is, that kind of problem will require disassembly of the tranny.  Should be pretty easy to see what's wrong once the case is cracked.
My rig is a fusion of Jazz and Funk; I call it JUNK
Offline pcguy
  • 343
  • 1996 Tracker 4x4
« Reply #2 on: June 11, 2006, 01:43:24 PM »
Thats the beauty of manual transmissions. when you open it up, can definitely see exactly whats wrong without much trouble at all.
Offline boscosfire
  • 14
  • Sammy Crazy
« Reply #3 on: June 20, 2006, 07:46:18 PM »
Found the problem, needle bearing on the main shaft locked up. Now I just have to find one, any suggestions my dealer can't find them.
