Quick Exhuast Question
  • 1370 Views
Offline Flork
  • 40
« on: June 09, 2006, 10:30:48 AM »
Could I run a 2 inch calmini exhuast system without a Cat. Converter? Is there any sensors, or other problems I would need to worry about if I did this?
1991 2 dr. Tracker, Auto
Thanks
91 2dr., 3spd auto, 5.12's, 30x9.5 BFG AT's on 15x7's, Calmini exhaust and plates.
Offline Flork
  • 40
Re: Quick Exhuast Question
« Reply #1 on: June 09, 2006, 10:32:12 AM »
BTW, no emissions laws here in Alberta
Jayzuki
« Reply #2 on: June 09, 2006, 10:50:38 AM »
Yes! I am sure it will reduce your overall soundquailty [ personal opinion ] and will be much louder than if you keep your CAT on. You'll get better fuel economy but will produce more harm-full emissions. Either way if your running CALMINI your good to go! I plan too cut the CAT on my next machine and run the MINI system. Also have no AIRCARE here.
Your talking about the FULL SYSTEM? HEADER TO CATBACK?
« Reply #3 on: June 09, 2006, 11:52:26 AM »
   I changed to 2" exhaust with no cat on my 92 and there were no issues.  Sounds a lot better too!!
Offline Flork
  • 40
« Reply #4 on: June 09, 2006, 01:09:26 PM »
Not going with the header. Just the exhaust.
I knew I needed a new muffler, but after my local exhaust shop got my truck on the lift they found that my cat was pretty rotten and I needed a new tailpipe section....So basically, I need an entirely new exhaust system.
I think I'll go with the filter combo...
Thanks for the replies.
Offline CodeBlue
  • 55
« Reply #5 on: June 09, 2006, 11:19:10 PM »
if your cat is the right size you could just take a big screwdriver and hammer/chisel out the honeycomb inside.
