where can i find a 1.6 for my samurai?
  • 10 Replies
  • 2536 Views
Offline zukzilla1662
  • 90
« on: June 06, 2006, 05:45:16 PM »
help cant find one.........lower prices
Re: where can i find a 1.6 for my samurai?
« Reply #1 on: June 06, 2006, 06:58:37 PM »
   Cheapest route is usually to find a local wrecked Tracker or Sidekick with a good motor, for sale.
« Last Edit: June 06, 2006, 07:00:16 PM by LilRed »
Offline droppedtracker
  • 238
  • its a tracker thing, you wouldnt understand!!!
« Reply #2 on: June 06, 2006, 07:01:49 PM »
you ever thought of dropping in a swift gt motor (1.3l 1300cc DOHC 100 hp)  into it?  it just so happens that i have a swift gt im parting out!! ;D ;D
Offline zuksofhazzard
  • 503
  • them darn Zuk boys
    • MOAB PICS
« Reply #3 on: June 06, 2006, 07:34:23 PM »
Fill out your profile or give a location.
You might have someone closer than you think.  ;)
  • 90
« Reply #4 on: June 06, 2006, 07:39:18 PM »
maine
« Reply #5 on: June 07, 2006, 11:22:22 AM »
There needs to be a 1.3L DOHC on the west coas  >:(
As far as a cheap 1.6L, the u-pull-it / junk yards are going to be the cheapest for JUST a working motor.
If you want to get A/C, Fuel Injection, Power Steering etc - I strongly suggest you buy a Sidekick / Tracker / Esteem and use it as a doner vehicle. You can buy one for less than all the individual parts will end up costing you. You can part out the rest of the bits you don't want, and even take some thing you may need (wheel lockers etc) in the future. Then, sell the body to a salvage yard. Some people have acutally MADE money doing this after parting out their doner vehicle.
~J~
  • 238
« Reply #6 on: June 07, 2006, 09:57:48 PM »
if your planning on adding performance parts the 1.3l DOHC motor is a way better platform than the 1.6l tracker motors, and the aftermarket support for the G13B is also superior :P
Offline CodeBlue
  • 55
« Reply #7 on: June 07, 2006, 10:24:49 PM »
From what i get off google.com the 1.3 dohc has 100hp/83lbft  ( unkown rmp range) while the 1.3 sohc from sammy has 69bhp/76lbft at 6000rpm/3500rmp .  Is this correct? if so i don't see why ppl down the dohc so much for torque.
  • 238
« Reply #8 on: June 08, 2006, 12:59:13 AM »
the G13B stock redline is 7000 rpm but with a chip can go up to 8600 rpms!!checkout www.teamswift.net  for all info on 1.3l DOHC,SOHC, 1.6l SOHC, 1.0l SOHC from metro fireflys, 1.0l SOHC factory turboed sprints, stc. and check out....
www.ssgti.net/main
www.turbinetech.ca  for performance parts. ;D
Offline CodeBlue
  • 55
« Reply #9 on: June 08, 2006, 10:08:15 PM »
These are the max hp/lbft at these rpms. I was woundering what the stats would be for the dohc. but I will check out the sites for sure. thanks  :)
« Reply #10 on: June 09, 2006, 05:02:58 AM »
I think a lot of people confuse power at low rpm with torque (certainly in the UK). The DOHC has a lot more torque but less low down power. The Jimny engine (G13BB) and the Vit 1.6 8V (G16A) both make 80bhp, the 1.6 is much better (easier to drive) off road as it makes its power and torque around 1000rpm lower.
