Curing Vapor Lock
  • 1051 Views
Offline noff21
  • 32
  • Find them... Please don't grind them.
Curing Vapor Lock
« on: May 22, 2006, 07:02:10 PM »
I have a 90 Samurai with EFI.  After working with it I found that the starter was siezing.... I thought it was the engine locked up...... I completly reworked the electrical....... including a new starter.....
After a minute or two lock-up again.
I pulled the plugs (but left the plug wires close to the holes NOT A GOOD IDEA)
I turned the key and it ran freely... except for the 4 fire balls flying from under the hood.
So it seems that my Injector is free flowing into the intake.  Is this a simple injector replacement? or a more serious issue?
Any help appriciated.... I can't go without my Zuki for too long.
90 Samurai 4" lift finally installed.  Now it's time for some good tires.
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
Re: Curing Vapor Lock
« Reply #1 on: May 23, 2006, 09:24:48 AM »
Un plug the inj. and see if fuel still flows out when cranking. If fuel does flow with it unplugged you have a bad inj. If fuel doesn't  flow then You prob. have a shorted ground side in the inj. harness or a bad Ecu.
      Kevin
Offline noff21
  • 32
« Reply #2 on: May 23, 2006, 10:09:42 AM »
thanks... I'll check it out.
