« Reply #1 on: May 16, 2006, 01:23:07 PM »
I don't have a tow bar, but I do know that the front bumper rebar(the steel part under the plastic skin) is only held on the front of the frame by 4 12mm bolts(you use a 12mm wrench to tighten/loosen them). This is not the strongest setup to rely on for towing your truck. Whatever you go with, make sure it's attached more securely than just to the bumper...
