WANTED...........
  • 1336 Views
Offline 89sami97jeep
WANTED...........
« on: February 14, 2005, 09:28:33 AM »
im looking for some motor mounts for a 1.6 8v FI motor to go into my sami with the 1.3 carb. i need the mm and the plate to adapt the motor and tranny(5 spd), i would like to buy used since im on a budget with this project. any help you guys could give me will be greatly appreciated. thanks    oh and also i need a rear drive shaft. if any one has a spare....
"Bow down to the inferior design of the Torx!
Something that hard to remove, must be respected.
Offline nitromax
  • 206
  • FunZilla's alive !
    • NitroMax's Pages
Re: WANTED...........
« Reply #1 on: February 14, 2005, 07:45:48 PM »
Maybe you can find some info you need here:
http://www.nitromax.nl/SAMENGINESWAP.HTM
Did it last weekend, forgot to take a pic of the enginemount, but all it took was a drill to drill an new hole, just a little more to the corner of the original mount.
I could try and get a picture of an original mount and point where to drill ( I might go to Suzi's Place this Friday )
No adaptorplate, this is real "LowBudget" !!!!!!
« Last Edit: February 14, 2005, 07:46:27 PM by nitromax »
1600 cc 8v, MegaSquirt EFI, Camden SuperCharger, Calmini 3" Shackle Reversal, IronMan 3"suspension lift, SPOA and 2"bodylift, 4.16 T-case, QuickLok rear, 33x12.5 ProComp XT's on 8"rims with 1"wheelspacers.
Check it all on : www.nitromax.nl
International editor |removethispart|@ www.izook.com
« Reply #2 on: February 16, 2005, 09:16:20 AM »
no adapter plate? how did you mount the trans to the engine?  my motor came out of a tracker w/ auto. i got a 5spd. and the holes dont line up good. i have saw where you can weld on tabs to the trans. but i dont have a tig welder....
