No idle!
  • 1660 Views
Offline brawnyrebel
  • 131
  • i've cought a case of samuraitis
No idle!
« on: February 15, 2005, 10:17:21 AM »
   It seems like when my choke shuts on my samurai it will no longer idle. Do any of you sammy experts out there have any suggestions for me? Thanks
If its not broken, break it
Offline zuksofhazzard
  • 503
  • them darn Zuk boys
    • MOAB PICS
Re: No idle!
« Reply #1 on: February 15, 2005, 01:35:55 PM »
Is is a stock carb? If it is then let me ask you, Does it run fine as long as you give it throttle? Does it run fine while you driving it? If it does, I would suggest double checking the ECM and making sure it is plugged in real solid. The ECM on a carb'd Samurai controls the idle. Just unplug it, and the plug it in firmly. That fixed a problem for me once.
Offline brawnyrebel
  • 131
Re: No idle!
« Reply #2 on: February 15, 2005, 10:15:05 PM »
 Yes it is carbed. i will try the ecm tonight
Offline brawnyrebel
  • 131
Re: No idle!
« Reply #3 on: February 17, 2005, 05:08:21 AM »
  I replaced the ecm with a extra one i had laying around. It seems to have done the trick. thanks alot
  • 503
    • MOAB PICS
Re: No idle!
« Reply #4 on: February 17, 2005, 06:07:33 AM »
I am glad it worked! Don't throw the other ecm away. It may be good still. Maybe it wasn't plugged in all of the way. Jeff
