Lift picture/infor thread
  • 31 Replies
  • 6521 Views
Offline AJMBLAZER
  • 2166
  • Your mom.
Re: Lift picture/infor thread
« Reply #15 on: May 11, 2006, 12:33:07 PM »
$45 from a local place.  BDS doesn't sell it's stuff online or through mail order distributors.  You have to find a local or semi-local distributor. 8)
http://www.bds-suspension.com/php/distributor.php
Offline 2K1USGV
  • 218
« Reply #16 on: May 11, 2006, 01:07:14 PM »
I had to have it shipped since the local BDS distributor didn't stock it.
Offline the_maplebar
  • 466
« Reply #17 on: May 11, 2006, 02:18:52 PM »
I see why they don't post prices on the internet, they are all over the price.  Mine were $30 a piece + $15 shipping for a total of $75.  They said I had to order 2 pieces, the invoice showed to pieces, and I received exactly 2 pieces not 2 pairs like I hoped after talking to AJMBLAZER  and others.  That is one wacky company.
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #18 on: May 11, 2006, 02:48:36 PM »
I think you got screwed by an uninformed or duplicitous dealer, not BDS.  I've always had good luck with BDS.
  • 466
« Reply #19 on: May 11, 2006, 06:27:12 PM »
I agree or there may be different distribution warehouses?  I opened the box packaged from the BDS warehouse, the invoice inside listed 2 pieces part #FSE3 and it only included 1 pair not two pairs.  I was in hurry at the time so I didn't question them much, but the distributor knew absolutely nothing about the kit for Suzuki's they had never ordered one before.
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #20 on: May 11, 2006, 07:56:17 PM »
Okay, you got screwed somewhere...not sure where...my bat-sense says that someone was trying to cover their |removethispart|@ss but I'm known for being a paranoid bastard... ;D
Offline Maroon Monsoon
  • 876
« Reply #21 on: May 12, 2006, 04:58:09 PM »
so is everyone who's used the BDS strut extenders 100% satisfied with them?
  • 466
« Reply #22 on: May 15, 2006, 08:21:51 AM »
I am very satisfied except for a couple of issues I had.
1)  My local distributor knew nothing about it and I got screwed on the price.  It's stil a nice part even for $75 and you know better now.
2)  The tolerances are so tight, it can be a real pain screw on.  As long as you are prepared for this it shouldn't be a problem.  Here's my thread on the problem http://www.zukiworld.com/forum/index.php?topic=11771.0
3)  I will wait to give judgement on how it works until I have used them longer.  My only concern is that it seems to add about 2.5" of droop which is more than every other product on the market.  That could be a good or bad, I suppose if it is bad there are alwasy limiting straps ;)
  • 876
« Reply #23 on: May 15, 2006, 11:57:03 AM »
so they add 2.5 inches of extra downtravel than stock? sucks that your extensions and quaddog's had the same problem. I hope if I get them someday I won't have  that problem although it seems there are a couple of ways to either bore out the extension or grind down the stock strut
yea, I'd like to know how those are working for you later on down the road.
thanks
Offline bzzr2
  • 1011
« Reply #24 on: May 15, 2006, 02:05:07 PM »
i think you will be ok with 2.5 inches, with the 1.5inch front spacer your lift is roughly 2inches.  have you jacked up the front and and let it hang down?  i'm wondering if the spring and spacer might loosen up if it droops too much.  just a thought anyway.  i'm still running the stock strut setup....
09 taco reg cab short box 4x4
  • 466
« Reply #25 on: May 15, 2006, 02:38:23 PM »
I'm not worried about the springs, on the passenger side I had to practically stand on the control arm to get the springs in there with the 1.5" spacers.  It would take a lot more droop for the springs to come loose.  I did notice with Tracker jacked up the passenger side axle was difficult to rotate by hand at full droop because the CV was binding up some.  If I raised the control arm some I could definately notice it free up and rotate easier.
Offline willhl
  • 41
    • Will's Photography
« Reply #26 on: May 15, 2006, 07:55:05 PM »
"passenger side axle was difficult to rotate by hand at full droop because the CV was binding up"
Hmmm that kinda sets alarm bells ringing for me, have you lowered the front diff?  From what I've heard it is generally a good idea if you lift the car over 2" but I would guess the same would apply if you let it droop too far as well.
1998 Grand Vitara, 4-door, 2.0L, No Mod's . . . Yet.
Offline bzzr2
  • 1011
« Reply #27 on: May 16, 2006, 03:51:01 PM »
right, i guess that is pushing it for sure then, the limiter straps you mentioned might be a good idea.  how much do you figure you moved it up before things began to free up?  i'd want to go up that +.5in more just to be safe if i was in that position.  it just isn't worth potentially f'in up the front end.  cv axle's are way to pricey on our model years.
  • 876
« Reply #28 on: May 16, 2006, 08:23:47 PM »
how do the 1.5 inch spacers work out with the struts left stock? kind of curious, don't think I'd have to worry much about CV angles like that because it wouldn't droop enough, doesn't have much travel up front the way it is.
does anyone know if there is a way to get axle drop brackets for 2nd gen kicks like ours other than getting the calmini 2.5 inch lift or making some?
thanks
Offline blacknight
  • 987
    • Gonzookin
« Reply #29 on: May 17, 2006, 08:50:50 AM »
thanks
I found a place that sales the just the front diff drop brackets for GV 's and sidekick.  Here the web site http://www.vttr.com.tw/e4X4.htm  If you want to  contact  them here the mail vttr.tw|removethispart|@msa.hinet.net atten.   Margaret.
George
The brackets are about $90 us and shipping some where around $40 to the US
