Lift picture/infor thread
  • 31 Replies
  • 6520 Views
Offline 2K1USGV
  • 218
« on: April 29, 2006, 02:10:28 PM »
Well since som many are now lifting thei Vit/Track I though I would start a thread with pics of the lifts as well as teh specifications. What would be nice is if people with lifts would post pics from the side, front and rear, as well as the front suspension geometry (front under the truck) so we can see teh CV angles on different lift heights. I'll be posting mine with a 1.5 inch suspension lift in the front and 2 inch in the rear + 2 inch body lift running on 245/75/16's. I have the BDS front strut extenders and rear ranchos from an 89 landcruiser.
« Last Edit: April 29, 2006, 02:42:23 PM by 2K1USGV »
Offline lowrezolution
  • 292
  • "Get bent!"
Re: Lift picture/infor thread
« Reply #1 on: April 29, 2006, 03:44:54 PM »
did you remove your front sway bar?
2001 Tracker LWB
Boondox coil spacers and BDS springs 3.25" rear lift/3" front lift,3" body lift. 265/75/16 Durango Mud Terrains. (32")
Offline Chevzuki
  • 71
  • Grand Vitara disguised as a Chevy Tracker
« Reply #2 on: April 29, 2006, 04:22:22 PM »
Looks good!  :)
2004 Chevy Tracker ZR2 4DR 4WD, 2.5 liter V-6, 4-SPD auto trans, P215/75/R15 Goodyear AT tires (for now), bone stock daily driver
Offline sherifon
  • 42
« Reply #3 on: April 30, 2006, 03:02:13 AM »
very  very  good  idea !!!!
Offline Maroon Monsoon
  • 876
« Reply #4 on: April 30, 2006, 11:03:54 AM »
front sway bar is in, you can see it behind the control arm
that lift looks pretty good
Offline r3cc0s
  • 321
« Reply #5 on: April 30, 2006, 11:40:50 AM »
I suggest that we keep this a sticky
I was wondering if anyone has a FAQ on how to install the Rocky Road 2" BL?
I'm thinking of ordering it, but I'm not a big fan of having to weld shifter extentions
  • 876
« Reply #6 on: May 01, 2006, 12:16:50 AM »
I just noticed that your bodylift is barely noticeable. 2 inch is a good height for the body lift on a 2nd gen kicker I guess. I also like the grille, how do you get the stock one out? finally, did you make those spacers or buy them somewhere and if you bought them where?
thanks
Offline hap
  • 38
  • huh?
« Reply #7 on: May 01, 2006, 12:05:07 PM »
Call them before ordering. I ordered mine a week ago and it probably wont ship until next week.
Offline sergi
  • 307
« Reply #8 on: May 02, 2006, 02:11:33 PM »
Nomaad did an excellent write up for the RRO bodylift on an XL. It should be the same. Here is the link: http://www.carneyco.com/ProjectNomaad.pdf
I'll post pics of mine when I can.
Suzuki Grand Vitara 3dr TurboDiesel
Barcelona, Europe
Aquesta és la meva màquina. Creus que em pots seguir?
Offline the_maplebar
  • 466
« Reply #9 on: May 02, 2006, 02:35:49 PM »
There is also a writeup for a 2dr Vitara here:
http://www.off-road.com/suzuki/tech/vitara_lift/
Offline 2K1USGV
  • 218
« Reply #10 on: May 10, 2006, 12:32:19 PM »
Hey Guys,
I'll be selling the suspension lift I currently have on the Grand Vitara. The lift consists of BDS 2" strut spacers that you can use with your stock strut bar. 4 HMWP Spacers (1.5" front and 2" rear) as well as a set of Rancho shocks that are 2" longer. I decided I don't want the GV quite so high as I already have the body lift installed. $200 for all if you're interested.
  • 876
« Reply #11 on: May 11, 2006, 12:30:36 AM »
how much were those strut extenders originally? was curious about that
Offline 2K1USGV
  • 218
« Reply #12 on: May 11, 2006, 07:58:29 AM »
They were about $60.
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #13 on: May 11, 2006, 09:51:04 AM »
Mine were about $45.
Offline 2K1USGV
  • 218
« Reply #14 on: May 11, 2006, 11:47:06 AM »
$45 Shipped?
