Is this worth the money?
  • 1819 Views
Offline INGERSOL
  • 158
  • BIG, LONG, AND BLACK
    • INGERSOL.COM
« on: February 17, 2005, 09:49:23 AM »
So I'm looking at importperformanceparts.com and I see what looks like a rebuild kit for my tracker.  So my question is:
If you go with the oversize 85mm pistons , and you choose the hold onto your nutsack 11:1 compression ratio pistons, rings, etc....what kind of performance improvement should we be looking at?
Suzuki Vitara 16V DOHC 1995cc  1999 +up
Engine
Code Stock
Bore Kit # Includes: Price
J20A 84mm EKSZ7VMPX  Complete Gasket Set
Copper Performance Head Gasket
ROSS Forged Pistons
   (84, 84.5, 85mm) and
   (9.1-1, 10.1-1, 11.1-1 comp ratio)
Performance Rings
Performance Wrist Pins
TOGA HP Main Bearings
TOGA HP Rod Bearings
Thrust Washers
$979
http://www.importperformanceparts.net/imports/pek-suzuki.html
Also...I've been looking at Suzisport's ECU re-programmer.  Has anybody tried it?  I've seen lots of similar products for regular american trucks, and the performance figures a reprogrammer can provide are astounding (especially on a diesel).  Anybody have an experience with this product?
Here's the link: http://www.suzisport.com/shop/ somewhere in there...
2003 Chevy Tracker
2.0 L Four Cylinder / 5-speed
Suzisport Headers
K&N Air Filter
Calmini Grill Guard / Tube Bumpers UK Factory Sunvisor RRO Coil Spacers Bridgestone Dueler Revo 235/75-15's
Offline wezzlegod
  • 227
  • under construction crowler
Re: Is this worth the money?
« Reply #1 on: February 17, 2005, 10:51:56 AM »
moter go boomboom after not much milage. yeah good luck with that one.
Offline r3cc0s
  • 321
« Reply #2 on: February 17, 2005, 10:55:04 AM »
unfortunately like myself
the 2.0 litre seems to work very hard
I think personally cause it's cam'd for low torque rpm
but it definately has enough power at 3700 rpm and up
I don't think it's worth while to get minimal power out of a engine not designed to be performance/high reving orentiated
Offline zuki1
  • 15
  • drop a gear and disapper
« Reply #3 on: February 17, 2005, 12:32:25 PM »
yea if your going mud running and can get some 100ll from the airport but if you want power why not put a 6 init
if it don't fit     lick it
