Question for those with aftermarket springs
  • 1373 Views
Offline 2K1USGV
  • 218
« on: April 26, 2006, 08:30:06 AM »
My question is regarding the spring rate of aftermarket springs compared to that of stock. I have installed 2" spring spacers in the rear and although I got a lift I also apparently increased the spring rate. So now the rear is really hard on bumps. I have rancho 5000's installed in the rear so that should soften the ride but it's still too hard. I want to go to a softer spring and I don't know if OME will do the trick?
Offline 2K1USGV
  • 218
Re: Question for those with aftermarket springs
« Reply #1 on: April 29, 2006, 02:05:39 PM »
Anyone?
Offline cj
  • 1276
  • I drive a really big ATV
« Reply #2 on: April 29, 2006, 05:00:52 PM »
Which model do you have?
Adding spacers can increase the rate but the problem may actually be the valving of your shocks.
