GV front brake servicing question
  • 19 Replies
  • 2194 Views
Offline the_maplebar
  • 466
Re: GV front brake servicing question
« Reply #15 on: April 25, 2006, 08:47:08 AM »
Worked perfectly, of course it's not very detailed.  The instructions are basically remove brake calipers, disconnect tie rod, disconnect steering knuckle from balljoint, etc...  On the first side I was reading the service manual constantly as I am completely new to doing anything but an oil change.  On the second side the BDS instructions worked great as a checklist to make sure I keep everything straight.
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #16 on: April 25, 2006, 05:35:29 PM »
Did you have to grind on the upper part of the knuckle?
  • 466
« Reply #17 on: April 26, 2006, 07:26:21 AM »
no, I didn't notice any clearance problems there.  The only thing I ground down was my strut to get the extensions to fit.  I will also have to grind off some of my shock mounts to get the new shocks in.
I did notice that some of the front end components are different on the Tracker than on GV's.  The brakes are a different model (both bolts are the same size), and I didn't notice a lip on the WMS that I have heard about which would prevent wheel spacers from fitting right.
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #18 on: April 26, 2006, 07:23:11 PM »
Lip on the wheel mounting surface...nothing like that on mine either.  Huh. ???
  • 466
« Reply #19 on: April 27, 2006, 10:34:59 AM »
