Front brake pad servicing
  • 11 Replies
  • 2084 Views
Offline AJMBLAZER
  • 2166
  • Your mom.
« on: April 22, 2006, 04:31:36 PM »
Well, the wife told me it was starting to brake funny.  I was hoping the front pads would last longer until I had the time to put the lift on at the same time...guess not.
So it's on jackstands waiting for the new Bendix semi-metallics.  Brakes aren't my thing so I'm hesitant in doing all this stuff.
Anything I should know or look out for while doing this?
Can I use an impact to get the caliper retaining bolts out?  They're in there pretty good and my 1/2" ratchet doesn't seem to want to budge them.
Offline Carnage
  • 2453
Re: Front brake pad servicing
« Reply #1 on: April 22, 2006, 06:41:28 PM »
did you spray them with WD40 and let um sit?
(If not the impact should be cool)
X32...................X32CarDomainPage...................X32
...................RyouBakua|removethispart|@Hotmail.com..................
!!!!!!!!!!!!!DON'T CLICK HERE!!!!!!!!!!!!![/color]
Offline WOY
« Reply #2 on: April 22, 2006, 08:32:07 PM »
Being a sliding caliper brake, all you got to do is to undo one bolt and the calliper will rotate around the other one then you will be able to get to the pads. However it is easier if you remove the one that is NOT the main sliding pin (from memory it was the one with the smaller bolt). I replaced mine with Ferodo Excel and they do not come with the shims hence I had to reuse the old one from the OEM brake pads. Note the orientation of the slims and fit them the same way. Push the piston home with a G-clamp.
I don’t remember the caliper bolts on my 5 yo GV being overly tight.
Good luck!
Offline bzzr2
  • 1011
« Reply #3 on: April 22, 2006, 09:13:05 PM »
the front pads are bad on my zr2 also... only 24km on the truck..  making a lot of noise when damp and wearing more than i expected.
09 taco reg cab short box 4x4
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #4 on: April 22, 2006, 10:04:10 PM »
G-clamp?
Heh, ours has been making the front wheels BLACK with dust as since we got it at 22k.  I think because of the crappy brake materials they have to use now by law this sort of stuff is unavoidable.
Offline Carnage
  • 2453
« Reply #5 on: April 22, 2006, 10:24:50 PM »
G-clamp?
what do you think of those brake dust blockers/shields?
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #6 on: April 23, 2006, 06:28:14 AM »
Not really necessary with better quality pads.  The OEM's have to use crappy materials now and more dust, in some cases A LOT MORE, is one of the results.
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #7 on: April 23, 2006, 09:03:55 AM »
Well, got the calipers and their brackets off.  Took a 3' long breaker bar and my rubber mallet but they came off.  Kudos to Suzuki for using caliper bolts that aren't little twigs.  I seem to remember my Ranger and my Ram having MUCH smaller caliper bolts...a similar process would likely result in snapped off heads. Lips Sealed
Looks like on both sides the inside pad was wearing faster than the outside pad to the extent where the inside pads are practically gone.  In addition the driver's side set seemed to be wearing at an angle which meant the inside driver's side pad was actually dragging the metal backing plate on the rotor where all the material wore off on the rear of it.Shocked
Now to go find some 8mm bolts at the local hardware store and get those rotors off.  I live in such a bustling metropolis  Roll Eyes that none of the machine shops are open today. Angry  Hopefully I can have them turned and have it all back together tomorrow.
Are there any bearings, races, seals, etc on the inside of the rotor?  Never had a Suzuki apart before.  Wish I had thought to take the hubs off BEFORE I disassembled the front brakes.
Since I need the 8mm bolts to take the rotor off...how do I reinstall it?  The FSM just says "reinstall rotor".
Offline blacknight
  • 987
    • Gonzookin
« Reply #8 on: April 23, 2006, 11:29:30 AM »
when you put the rim on it will press the rotor back in place.
George
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #9 on: April 23, 2006, 11:34:27 AM »
Thanks.  Like I said, I don't know squat about brakes.
Offline JDMCRX
  • 1110
  • 02 Grand Vitra Pimp lol
« Reply #10 on: April 23, 2006, 07:28:27 PM »
140,000km on mine 3rd time doing a break survice but there ineed of change tho
01 GRAND VITARA
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #11 on: April 23, 2006, 07:43:19 PM »
Wow, don't feel so bad about going 42k with the original set then.
