jeep tj coil spacers
  • 1151 Views
Offline TrAkLsI
  • 61
« on: April 12, 2006, 11:43:12 PM »
is it safe to run a jeep 3" spacer to the rear of a 95 2dr tracker thanks,
Offline the_maplebar
  • 466
Re: jeep tj coil spacers
« Reply #1 on: April 13, 2006, 07:07:29 AM »
You know you will have to modify the jeep spacer right?  You have to bore out the center hole to fit.  As far as being safe; I think so, but you axle will bind on the pinion mount before you get much droop if you go that high.  So you will need to fab up a pinion mount spacer too.
