Protecting your Electronics
  • 1076 Views
Offline mikelx
  • 17
« on: April 12, 2006, 07:57:53 PM »
What do you all use to protect / keep water off your coil and distibutor (sp) when you go off roading any suggestions , like a plastic bag and some elastics??? Do you spray the spark plug wires with silcone??
1975 CJ5 Jeep (Sold)
1984 GMC Jimmy Full Size 4X4 (Ex Mud truck now Tow Beast)
1991 GMC Tracker 4X4 (Homemade 3" lift and 31's)
Re: Protecting your Electronics
« Reply #1 on: April 12, 2006, 11:38:28 PM »
I use wd40 ( I used to use lps?)but not down the spark plug hole in a 16 valve engine, on an 8 valve I would pull the boots off and spray them real well, and the outside of the cap is ok, I have sprayed the inside but only on a five foot deep or more water hole or river and wiped it out afterwards just incase of collecting dust inside.
Offline mbmarkyb
  • 461
    • UK Vitara
« Reply #2 on: April 13, 2006, 09:40:32 AM »
Silicone spray .   puts a coat over it all and had no issues running under water
Markyb (UK)
UK Vitara JLX SE
