I have a 1991 sami thats fuel injected.
My problem is after running for about 5 min, the motor looses spark and dies. I go to start it and there is no spark from the coil to dist. after trying to start about four times it then starts sparking and starts up again and runs for another 2 to 3 minutes and then dies again.
1.I used my timing light to make sure on spark condition.
2. Then i checked for continous 12v to the coil, that checked out find when running and even after it died with the key switch on.
3. then i checked the coil.
a. right after the engine died, primary was 1ohm, secondary was 12.45kohm
b. I got the engine running again and turned it of from the key switch and then checked the coil again. primary was 1.6ohm and secondary was 12.33kohm,
I guess my next steps are....
1. checking if the ignitor is still working when i dont get spark. I guess make sure the ecm is still sending a signal to the ignitor.
2. test the pick up to the dist is functioning correctly.
If any one has any ideas or suggestions please reply, it is my daily driver.
Thanks,
Jack Jr.
