Have question about rear passenger brake drum.
  • 932 Views
Offline dodgefan
  • Suzuki and Jeep those are my things.
« on: April 04, 2006, 05:00:33 PM »
The question is simple, how do you get it off?  There is a noise coming from the brake and I need to inspect it.
Growing up to be a Jeep
Offline crikeymike
  • 713
    • http://www.wazuks.com
Re: Have question about rear passenger brake drum.
« Reply #1 on: April 04, 2006, 05:06:53 PM »
tap and rotate it.  If that doesn't get it, use a rubber mallet on the studs for a second in the middle.
Tapping and rotating has almost always worked for me unless your handbrake is still on or your shoes are stuffed.
1993 4-door Sidekick
4.24:1 t-case
Offline hobgoblin
  • 224
« Reply #2 on: April 04, 2006, 06:09:33 PM »
You forgot to them them to take the four bolts in the center off.Mine was a SOB to get off....Had to beat it with a hammer to get it off....
Later Tom K.
mudfkr
« Reply #3 on: April 05, 2006, 03:46:25 PM »
I all ways leave the wheel on and take the four nuts off at the axle that way if it is a PITA
 to get off I just hit the inside of the tyre a few times in different spots to loosen it up.
