2.5 and 2.7 liter oil pan compatibility?
  • 15 Replies
  • 2937 Views
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
« on: March 30, 2006, 12:12:10 PM »
Anybody know off hand if the 2.7l and 2.5l oil pans are the same?
The 2.7 motor I pulled has had its pan repaired in the past, looks like it was probably a careless jack handler's work.  While its out, figure I'll replace it.  Guess I could call a dealer.
XL-7 front coils
1.5" rear coil spacers
95XL7
Re: 2.5 and 2.7 liter oil pan compatibility?
« Reply #1 on: March 30, 2006, 12:19:46 PM »
I believe there the same pan,the lower pan costs about $80
I found the following on suzukicarparts.com using their online parts finder.
 Description: OIL PAN
Part #: 11520-85F10
Price: $62.51
Categories:
Collision > ENGINE > ENGINE
Mechanical > GROUP 4 - ENGINE > ENGINE OILING
« Last Edit: March 30, 2006, 12:29:54 PM by 95XL7 »
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
« Reply #2 on: March 30, 2006, 12:46:20 PM »
Thanks!
Looked at suzukicarparts.com, thought they listed the lower pan for 180.  That concerned me.  Then you said 80.  That sounded better.  Called a dealer, parts guy quoted $56.  Told him to place the order.  Not cheap, but I wouldn't be able to sleep knowing that splotch of JB Weld was down there keeping everything in..
« Last Edit: March 30, 2006, 01:26:50 PM by beercheck »
XL-7 front coils
95XL7
« Reply #3 on: March 30, 2006, 01:02:58 PM »
do you have any other parts left from the XL7?
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
« Reply #4 on: March 30, 2006, 01:25:22 PM »
I still have EVERYTHING left, at the moment.  Reassembly hasn't quite begun yet..  I know I'll be taking engine/tranny/tc, shifter, stereo, wiring harnesses, front and rear axles/brakes/wheels, front (and perhaps rear, we'll see) springs, mirrors, parking brake lever, pedal assembly, under hood insulation, firewall insulation, under hood mercury light, exhaust.  I'll probably take the ABS equipment.  I might take some rear air components.
Does that leave anything you'd have interest in?  Seats, glass, air bags, steering, plus a bunch of displaced 2003 Tracker componentry, I guess.
XL-7 front coils
95XL7
« Reply #5 on: March 30, 2006, 01:54:27 PM »
 :o Nope.... was interested in the rear brake assemblies.
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
« Reply #6 on: March 30, 2006, 02:01:42 PM »
So......I've got a line on a 5-sp from an XL-7 at a junkyard.  What would it take to use that instead of the auto?  I'm thinking it would just be the tranny, the ECM and the correct flywheel for the motor.  I would think the chassis wiring harness from the 5-sp Tracker should work.  Am I missing something major?
I should probably just get back to work.  The last thing I need is to drag this project out any longer..
XL-7 front coils
95XL7
« Reply #7 on: March 30, 2006, 02:07:19 PM »
I could use the rear emergency brake cables from the tracker rear end.
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
« Reply #8 on: March 30, 2006, 02:11:34 PM »
I'll get to swapping the rear end (hey-oh!) in the next few days.  If I don't end up needing 'em for some reason, shouldn't be a prob.
XL-7 front coils
95XL7
« Reply #9 on: March 30, 2006, 02:14:31 PM »
Thanks much! I bought a rear brake set-up from a GV and the ass...e's cut the brake cables.
I'm in the middle of swapping over the brakes and axles now.
Offline the_maplebar
  • 466
« Reply #10 on: March 30, 2006, 02:24:41 PM »
I don't think so but just to make sure, does your 03 5spd 2.0L have the steel front diff and 3rd?
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
« Reply #11 on: March 30, 2006, 02:27:14 PM »
That would've been nice, huh?
But....nope.
XL-7 front coils
Offline cj
  • 1276
  • I drive a really big ATV
« Reply #12 on: March 30, 2006, 03:14:24 PM »
If you ever think you will want to put some crawler gears in your transfer you can't do it with the manual or the 5spd auto.
  • 6558
  • 64
« Reply #13 on: March 30, 2006, 04:14:35 PM »
The auto won't work either. You need a GV automatic to run the Sidekick crawler gears in a GV or Sidekick t-case. GV automatic will bolt to and plug into XL.7 engine. That is what I have in my Sidekick. XL.7 2.7 engine/GV auto 4-speed transmission/Sidekick T-case with Calmini crawler gears - no mods or adapters needed.
Offline cj
  • 1276
« Reply #14 on: March 30, 2006, 04:29:40 PM »
Hmm... so the XL-7 4spd autos can't take the gears either. Living and learning  :)
