How to remaove transfer case shifter
  • 1612 Views
Offline Jimiweld
  • 234
    • www.fullfusion.ca
« on: March 25, 2006, 07:59:36 PM »
hey guys
  I just did my 3" budget lift and it turned out alright, tomorrow I'll slap on a temporary bumper. My problem is, how do I remove the transfer shift lever, I would like to extend it.
  I read the Haynes manuel and it's really quite useless. I notice there are two bolts one at the front and one at the back just below the rubber boot. If I remove these can I pull the shift lever? Or does the entire cover need to come off from the transfer case?
Thanks
Jim
Offline hobgoblin
  • 224
Re: How to remaove transfer case shifter
« Reply #1 on: March 25, 2006, 08:23:43 PM »
Ok,
Remove the boot from the body,now see the small round black boot around the shifter,it has a metal lock ring on it,some say it can be reused but I just cut mine off and used 2 zipties to replace it.Now there's a round metal piece in side the transfer around the shifter.Push down and turn counter clockwise...It's kinda hard to do but then the shifter will lift right out.Just make sure you get it back in right...test it before you put the boots back on.I extended mine at the bottom so the shifter still had all the same angles etc.
Later Tom K.
« Reply #2 on: March 25, 2006, 11:02:00 PM »
I think he's working on a tracker not a samurai.
« Reply #3 on: March 25, 2006, 11:20:12 PM »
Same removal process, wear gloves
to make sure you don't slice the ends
of your fingers on that bayonet fitting
« Reply #4 on: March 25, 2006, 11:34:01 PM »
Ok, was looking at my friends kicker 3 and was a whole diffrent type of shifter.
« Reply #5 on: March 25, 2006, 11:35:21 PM »
Yep, that Kicker3 one is different
Offline Jimiweld
  • 234
    • www.fullfusion.ca
« Reply #6 on: March 26, 2006, 04:26:17 AM »
Thanks, I'll go try that this morning. If the rubber boot is rotted will crap be able to get into my transfer case, or is the shifter isolated?
« Reply #7 on: March 26, 2006, 09:09:14 AM »
No, junk like mud and water can get in there
