Best way to bolt on home made bumper?
  • 10 Replies
  • 2882 Views
Offline Jimiweld
  • 234
    • www.fullfusion.ca
« on: March 23, 2006, 07:25:59 PM »
Just wondering what others have done in the past for bolting on home made bumpers. The 4 little bolts that hold the original front bumper on aren't strong enough for any pulling.
 How do the aftermarket bumpers fit on?
 I don't want to put the stock bumper back on so I think I'll make something. Do you drill through the frame and sleeve it with tube and then run larger bolts all the way through?
Thanks
Jim
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
Re: Best way to bolt on home made bumper?
« Reply #1 on: March 23, 2006, 07:34:55 PM »
WHat I did was drill a 1" access hole in the front of the frame so that I could then drill much bigger 1/2" bolt holes and snake the nuts in through the access hole. Once the bumper was securely bolted, I covered the access holes with a rubber plug. I also used heavy duty 2" muffler clamps around the forward tubular crossmember and welded on pipe from the saddle up to the underside of my winch plate. I also tied the custom made skidplate into the back of the bumper, the front lower A-arm bolts and the crossmember just behind the engine... Definately very strong! LOL!
« Reply #2 on: March 23, 2006, 08:21:26 PM »
I think a mount that works it's way into
the front body mount would be very strong,
the 4 stock 8mm bolts could be used for holding
the bumper on while you get the big body bolts
installed.
Offline hobgoblin
  • 224
« Reply #3 on: March 24, 2006, 09:06:28 AM »
Hello,
I took some pics for you,I used the stock ones,made a winch mount which is welded to the frame.There are two bolts that hold the winch fairlead and bumper,and two mounts that I drilled and tapped on the sides.So that's 8 total bolts holding mine on.
Later Tom K.
Offline Quaddawg
  • 1622
    • My Ebay Store
« Reply #4 on: March 24, 2006, 09:13:16 AM »
Tom, that thing is coming along nicely!  Is that the winch I delivered to your buddy?
Offline Digger
  • 1991
« Reply #5 on: March 24, 2006, 11:09:38 AM »
I LOVE the headlight covers! Makes the truck look like it's chillin behind sunglasses... LOL!
Offline hobgoblin
  • 224
« Reply #6 on: March 24, 2006, 12:26:39 PM »
Yes, That's it and it works great...Had it locked in 4 low with the E-brake pulled and It will drag it just like the Tracker was not even there..And that was up hill :o..Dad said that I could run over trees(bumper)...If not just winch up them.... ;D
Later Tom K.
Offline Quaddawg
  • 1622
    • My Ebay Store
« Reply #7 on: March 24, 2006, 01:09:22 PM »
I was thinking about getting some of those covers, to protect from rock damage.....  Plus it would match my front end...
Offline hobgoblin
  • 224
« Reply #8 on: March 24, 2006, 01:50:19 PM »
And they look cool....Might have to get some rear ones too ;)
Later Tom K
Offline brlj
  • 512
    • Bills 93 Tracker
« Reply #9 on: March 24, 2006, 02:00:45 PM »
I welded some pieces of angle to the front of the boxes and drilled more mounting holes thru the angle and bumper mount.
Bill
Offline Jimiweld
  • 234
    • www.fullfusion.ca
« Reply #10 on: March 24, 2006, 07:21:42 PM »
Thanks for the ideas for fixing the front bumper to the frame. Until I get a winch to build my front bumper around I think I will use a piece of 4" c-channel and attach it per the comments here.
Thanks
Jim
