I think i Blew up my Clutch (samurai)
  • 1547 Views
Offline Praise Him
  • 256
« on: March 22, 2006, 06:21:08 PM »
So i have a 86 zuki sammy, i went mudding last sunday night, and i got into it pretty hard in the water and mud and clay in 4 LOW, using the clutch alot, and at the end of the day i unlocked the hubs and put it in 2WD and started the drive home, i noticed that there was a bad burning smell comming from my truck and some white smoke under the hood,
and i had almost no clutch pressure to in gauge the clutch so i could shift,
i have parked the truck untill i can figure out the problom, Its really hard to shift gears, and it smells like burnt clutch while im driving , then my get white smoke or something from under the hood,
What could it be ? anyone go threw this also ?
sammy/toy axles/locked/geared/cased/36's
Offline da_tub
  • 307
Re: I think i Blew up my Clutch (samurai)
« Reply #1 on: March 22, 2006, 09:18:21 PM »
well if it smokes like a clutch, and smells like a clutch,, then i would say yo dude your clutch is heading south...( :'( good thing there easy to do  and fairly cheap..
91 four door ,and some stuff
Offline Ian
  • 50
    • Island Rock Crawlers
« Reply #2 on: March 23, 2006, 09:37:43 AM »
Sounds like you may have just packed the clutch full of mud.  See if you can remove the inspection cover and get in there with a garden hose to clean it out.
Offline reb
  • 195
  • Victim of CRS--Can't Remember Anything.
« Reply #3 on: March 23, 2006, 10:02:32 AM »
If it smells while you are driving, it might just be slipping.  Adjustment might fix it for a while.
Offline Praise Him
  • 256
« Reply #4 on: March 23, 2006, 04:28:45 PM »
Yeah, im gonna go check it out in a bit, it will barly go into gear, and the clutch is on the floor, and barly pops back up....
Offline Praise Him
  • 256
« Reply #5 on: March 23, 2006, 06:19:28 PM »
well, i just got done playing around under there, I noticed the lower clutch cover was missing.. :-[  lol, so when i was cruisin threw the mud holes mud, water and rocks were going into my flywheel and clutch, i also noticed i had rust on the flywheel, and the creeking noise when i engauge the clutch was small rocks and wahtever else was in there rattleing around or grinding, I started the truck and faced the front down hill and sprayed water into the flywheel hoping i could get some of that shit out of there, the creeking now went away,
as for the clutch cable it was barely on the threaded screw..lol
clutch works for now, and its drivable, might have to buy a clutch and resurface the flywheel tomarrow, just to get by untill i get all my parts for my 1.6 16v swap,
thanks for the help
