Tracker Width
  • 3247 Views
Offline joe_and_jeep
  • Why have a Rev Limiter and not use it?
Tracker Width
« on: March 20, 2006, 10:07:21 PM »
What is the axle width of a Track/Kick.  WMS - WMS?  I am thinking about going solid axle on my 96 and looking at my options.
96 Tracker DD - 2in, 30s
95 Tracker Under the Knife - 4.3V6 - Rest Unknown
91 Jeep YJ Full Cage, Tri Link, D44/D44 35s
84 Jeep XJ Doubler HP44/9IN 35s
Offline Shredder
  • 389
    • Me & My Rig
Re: Tracker Width
« Reply #1 on: March 21, 2006, 06:23:23 AM »
I think I have these correct. If not, someone fix me.  ;)
Current Suzuki IFS Specs
Lug pattern: 5 x 5½"
Width: 57.5" / passenger side differential
Spring location: Frame Rails are 29½" Front. 32" Rear
Common ratio: 5.12:1, ratios of 4.30, 4.62, 5.38*, 5.62* and 5.83:1 are available but some are rare (* Rare)
Suzuki Samurai Front Axle
Width: 52.5" / passenger side differential
Spring location: Spring-under ? inches apart.  Perch width: ? inches
Common ratio: 3.73:1, ratios of 4.30, 4.62, 5.12 and 5.83:1 are available
Bonus tips: Although not considered a strong axle by hardcore off-road enthusiasts it is considered to be stronger than the stock IFS. This axle is narrower than needed and so wheel spacers are needed.
’82-’86 CJ Dana 30 Wide-Track Front Axle
Width: 56" / passenger side differential
Spring location:  27½" apart.  Perch width: 2 inches / Spring under axle
Common ratio: 2.73:1 but ratios down to 5.38:1 are available as long as you have the matching Suzuki ratio.
Bonus tips: These Dana 30s have disc brakes.  The 260 U-joints can be upgraded to 297s for even more strength.
'79-85 Toyota PU/4runner
Lug pattern: 6 x 5½"
Width: 55.5" / passenger side differential
Spring location: 29" apart.  Perch width: 2 inches / Spring
Common ratio: 4.88:1, 3.70, 4.11, 4.56, 5.29, and 5.71:1
Bonus tips: (F&R Needed)
'90-97 FJ80 and FZJ80 Landcruisers
Width: 63.5" / passenger side differential
Spring location: Coil spring mounts
Common ratio:  4.88:1, 5.29:1
Offline hcgalvin
  • 1695
    • Granite Path
Re: Tracker Width
« Reply #2 on: March 21, 2006, 12:31:47 PM »
Also came with 4.10's ... most of em did.
Heather Galvin
Re: Tracker Width
« Reply #3 on: March 21, 2006, 09:14:42 PM »
I got Waggy 44s that are 58 1/2.  They will make a nice swap  ;D  After I get some other projects done.   I'm just worried about 'splodin' my front third.
Offline Shredder
  • 389
    • Me & My Rig
Re: Tracker Width
« Reply #4 on: March 22, 2006, 08:41:25 AM »
A friend of mine has those on his. It is a good width. I have a hard time finding any around here though. Here is a shot of his rig.
Offline hobgoblin
  • 224
Re: Tracker Width
« Reply #5 on: March 22, 2006, 03:47:40 PM »
Nice Ride,What size tires are they?
Offline Shredder
  • 389
    • Me & My Rig
Re: Tracker Width
« Reply #6 on: March 22, 2006, 03:55:24 PM »
I know they are 35" Boggers and I think they are 13.50" wide.
