What stock parts have you broken?
  • 35 Replies
  • 6221 Views
Offline Somer
  • 143
  • Hey, is it suppose to do that!!
    • D2
Re: What stock parts have you broken?
« Reply #15 on: February 22, 2005, 09:13:53 PM »
I broke my stock engine ...2.0L V6 :P....probably the valve seals..
« Last Edit: February 22, 2005, 09:14:27 PM by Gravel »
Offline Whipped
  • 141
« Reply #16 on: February 22, 2005, 09:24:06 PM »
I broke the windshield ! I was joking around and headbutted it from the inside and it shattered like into a million pieces.
Offline Speedracer7c
  • 2210
« Reply #17 on: February 22, 2005, 10:10:54 PM »
Only thing to go on me was my timing belt tensioner, and my fuel pressure regulator.
Offline MB
  • 223
« Reply #18 on: February 23, 2005, 04:07:47 AM »
Would my Sammi beating the heck outta 2 CD players count ?  ;
« Reply #19 on: February 23, 2005, 04:11:57 AM »
Only if at least one of them has fallen out of the dash from being beaten around ;D
Offline mineisbroke
  • 134
  • yip
« Reply #20 on: February 23, 2005, 10:07:01 AM »
every piece of the front diff . ring and pinion , spider gears , carrier ,housing , and the hard axle . the cv joints , the end of the cv axles . headlights windows windows windows .gas tank , crossmember , windshield ,shocks , struts ,frame , control arm , and I HAVE ONLY BEEN WHEELN A ZUKE FOR ABOUT 3 MONTHS . I love it !  ;D
Offline tracker8wr
  • 568
  • THE BIGGER THE BETTER
    • my home page
« Reply #21 on: February 23, 2005, 10:13:52 AM »
apperantly a bent strut tower, steering shaft,rear tire mount, 3 alternators, 2 batteries, 4 drivshaft flang bolts. ican't think of anything else right know.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
Offline Hard_on_riggin
  • 42
  • play in the mud
« Reply #22 on: February 23, 2005, 01:55:13 PM »
 ;D Hey there guys it is wonderfull to know i am not alone in the zooky world, I have had two rigs in the past 4 years and now driving full cal.kit big tires and bad aditude aimed at small jeeps.
I have learned much about my zook 1997 sidekick
If i can figure it out i will post pic. your rigs look great.
abit more rugged then mine but mine has most of the under sided parts.
I have lost the plastic button on the reclining back seat.
One cd player (got wet)
shift knob ( where would that go?)
The small guide for the top of the window . (trash)x6 or so
front windshield.
soft top now running fiberglass top (noisey)
One set center line alum.rims look great bad choice.
one set 32" tires now 33" much better need 35 soon
rear richmond gear set and pinion. My fault will not go there.oil dont forget to run with oil.note to self.
2 front housings saving up for anvil..
set shock
set front struts..
all members and t gase mounts.. now have armour no more problem.
head light bulbs by the bulk pack..
head light housing cant get the mud out.
and the last thing that comes to mind is the tail pipe i know i broke this because i dont think all that black smoke is right?
Plays in the mud!!!!!
mudfkr
« Reply #23 on: February 23, 2005, 10:13:43 PM »
Front housings, C/Vs, inner axles and R&Ps (too many to remember.)
Stock clutch x2
Starter motors x3
Auto hubs 1 set
Exhaust ( Run it over myself  :P)
Rear wheel bearings, brake shoes and wheel cylinders (mud kills them regularly)
Front grill (fence post attacked it)
Windscreen   (Tree attacked it)
« Reply #24 on: February 24, 2005, 08:14:17 AM »
I forgot to mention the exhaust.  Broke it into 3 pieces when I didn't quite make it up a short vert climb and droped the rig on the tailpipe.
Broke the center flange, both sides of the muffler, and filled the tailpipe with about 4" of packed dirt/mud.  ;D
Offline madvitara
  • 45
  • Mud i love it
« Reply #25 on: February 24, 2005, 08:33:22 AM »
Nothing on my first zuki a 83 sj
External door handles on my 89 sj410 it got to the point that i had to leave the windows open even if it was raining ::),,,, SJ zukis are narrow but so where the tracks we drove it up!!
Not broken the vitara yet  (side kick as u americans call them) but that will only be a matter of time
Offline ZukRebuild
« Reply #26 on: June 13, 2012, 12:04:18 PM »
1989 suzuki samurai
Ring and Pinion
Nothing beats a samurai
what the hell you looking down here for? haha
Offline tuxblacray
  • 20
    • Tuxblacray Photos
« Reply #27 on: June 16, 2012, 08:40:31 AM »
7 years later and this thread still lives.... but its a good topic. :laugh:
Lets see I recently pulled of my drivers door handle and sent it flying into a new home in a tree...
Rear driveshaft U-joint decided that it DID NOT like the angle of the crawl back to dry land after leaving the creekbed....
Passenger mirror musta had something against the road vibrations that emit from TSL swampers as the head nut snapped off...
Just minor stuff.... but then I am tweaking around on it constantly. ;D
Offline Capt
  • 738
  • 28
« Reply #28 on: June 17, 2012, 05:32:12 AM »
I'm in the KILLED AM/FM/CD player Group (Several), Nevada "Alkali" dust just gets into every thing (1) and Trail Pounding others.
Also I have Rear Spring issues; Lateral Cracked 2, Wrapped up one at the front Eye, but it has always made it home!!
AND THE DREADED CRANK KEY WOBBLE OUT !!
CAPT
Offline mverley
  • 652
  • 20
  • SPACE JUNK
« Reply #29 on: June 17, 2012, 07:52:33 PM »
All of these are Samurai parts (won't list the parts from my non-samurai wheeling rigs):
1.  Multiple front and rear wheel bearings.
2.  EFI ECU (twice)
3.  2 head units (both completely submerged in water)
4.  4 windshields (most spectacular one was a tow hook from the backside...whizzed right by my head)
5.  Soft top (see above)
6.  4 rear axleshafts, 2 each side
7.  One stock front birfield joint
8.  Two inner longfield axle shafts
9.  at least 5 alternators
10.  One transfer case (split in half)
11.  One transmission (input shaft broke and destroyed the clutch and transmission case)
12.  One stock 1.3l engine (ran out of oil, oops)
13.  2 1.6L VW diesel engines (have one on video where the crankshaft broke in half)
14.  One front driveshaft
15.  One rear driveshaft
16.  Numerous u-joints in all 3 driveshafts
17.  One tire sidewall (hole was the size of a coffee can)
18.  One brake line (snagged on a tree limb)
19.  One lock-rite locker side gear (destroyed when axle shaft broke)
20.  2 or 3 tcase mounts and arms
21.  At least 3 motor mounts
22.  One head gasket
23.  One set of hub bolts (sheared all 6 off, might have been loose)
24.  2 shocks (both due to contacts with foreign objects)
25.  One stock rag joint (off road, so no loss of steering on the road)
That's all I can remember for now...that list was all on my own Samurais; nothing pirated from a friend's rig!
My rig is a fusion of Jazz and Funk; I call it JUNK
