SWIFT GT ENGINE SWAP
  • 22 Replies
  • 4977 Views
Offline prairie_dog
  • 234
  • 85/413 tin top
« on: February 23, 2005, 03:52:59 PM »
hey, anybody know how much is involved in this swap to a zuki. I heard these things have something like 100hp, do they bolt to tranny or adapter? old intake or GT one?  (I wanna stay carbed) What year of GT am I looking for? :)
Re: SWIFT GT ENGINE SWAP
« Reply #1 on: February 23, 2005, 04:02:54 PM »
There is one in the Garage Sale area
I think the blocks are the same family,
but the distributor sticks out the back
of the engine, which will hit the firewall
on a Sammy, I have read that you can get
a flat distributor cap, so the wires come
out from the side, giving just enough room
to get the wires on and the cap into place
Offline mbmarkyb
  • 461
    • UK Vitara
« Reply #2 on: February 23, 2005, 06:40:21 PM »
i have heard that you can get a mod to move it will see if i can find it
Markyb (UK)
UK Vitara JLX SE
« Reply #3 on: February 23, 2005, 10:56:11 PM »
Zukisport in Aus or DG tuning in Belgium?
  • 6544
  • 64
« Reply #4 on: February 24, 2005, 12:34:57 AM »
Why would you wanna be carbed? That engine has a really good fuel injection system... Anyway that's beside the point because it would be very hard to put a carburator on the twin cam engine. One would have to make an intake manifold. Brent from Trail Tough did this swap several years ago in one of his earlier Samurai it was featured on truckworld.com. Pictures from that article may give you some ideas as to what's involved and what the engine looks like. There is also a web site for the Swift GT that has info on the engine itself ssgti.com The engine will bolt directly to the tranny and use the Samurai engine mounts with no modification. The distributor cap will hit the firewall so there's work to be done there and depending on lift you may need to adapt the Samurai oil pan to the GT engine. Wiring in the engine can be done by self or by sending your harness to Trail Tough.
Good Luck, Eric
Offline Suzuki1.8
  • 283
  • Tires so low looks like i'm riding on blades
« Reply #5 on: February 24, 2005, 01:25:36 AM »
isn't the engine from a swift a 1.8? Wouldn't it be easier to just find a 1.8 out of a sidekick sport and put it in, due to no distibuter? And they make 120 hp stock.
« Reply #6 on: February 24, 2005, 01:29:37 AM »
The older swift gt's area a twin cam 1.3 I think they had different piston rods also to handle the power.
Offline chet
  • 556
  • Zuki time!
« Reply #7 on: February 24, 2005, 01:57:53 AM »
for swift GT info see www.teamswift.net
A couple of guys up here have this swap and they are really high strung engines not good for rock crawling as you need really low gears to keep the engine in its power band. A 1.6 swap would be better in my opinion.
I had a swift GT and they fly but the also weigh 2000lbs!
  • 6544
  • 64
« Reply #8 on: February 24, 2005, 03:02:42 AM »
Oh yeah, the twin cam bottom end is all forged and there is stiffening girdles for the bearing caps. It's a cool LITTLE motor...
« Reply #9 on: February 24, 2005, 08:17:14 AM »
I think the 89 Swift GTI has a carb if you want to avoid wiring up the injection system.
Offline prairie_dog
  • 234
  • 85/413 tin top
« Reply #10 on: February 24, 2005, 04:02:36 PM »
Thanks for the tips, let the hunt begin!!!
I wanted to stay carbed to get around the pump or tank mods and less wiring :-[
Offline andyt87
  • 146
  • I LPVE ZUKI WORLD!
« Reply #11 on: February 09, 2007, 09:57:17 AM »
hey... not to sure if replying to this will work seen as its quite an old topic... what the hell tho eh!
Ive been looking for an engine i could put into my new build... had always wanted to put the swift motor into my old Sami... ended up going for an 8v vitara motor, had all sorts of problems with it.. but when it worked... boy it was good!
someone said that the engine will just bolt in place... no need for any adaptions... appart from the dizzy cap mod... which i have found for sale at www.rhinorays.com might .co.uk... can be bothered to check it..
if anyone else could verify that the engine will just drop in without any welding or the like please do!!
many thanks....
1988 SJ 413
1986 SJ 410
1992 Samurai Sport
1989 Santana 410
« Reply #12 on: February 09, 2007, 10:55:11 AM »
I'm 99% sure the box mates up, I don't have any links that says it does, this link just says that you need the sammy clutch
http://bbs.off-road.com/ubbthreads/showflat.php/Cat/0/Number/1542892/an/0/page/9#Post1542892
Give Rhino Ray a ring he's a helpful bloke and builds a nice winch bumper too  ;D
http://www.rhinorays.co.uk
Offline chet
  • 556
  • Zuki time!
« Reply #13 on: February 09, 2007, 09:27:13 PM »
bolts up tothe tranny but engine mounts are different.
Offline Carnage
  • 2453
« Reply #14 on: February 09, 2007, 10:04:43 PM »
theyre not that friendly though
