speedo reading
  • 1396 Views
Offline sidekick101
  • 128
  • best site on the net
speedo reading
« on: March 11, 2006, 09:32:30 AM »
with puting my 235's on, shoudl i expect anychange in my speed. when i'm doin 100km/h am i really doin 110 0r 90 or 100? anyone ever check theres? thanx again
1993 sidekick JX, 2 dr, soft top, automatic,
Offline AJMBLAZER
  • 2166
  • Your mom.
Re: speedo reading
« Reply #1 on: March 11, 2006, 12:07:24 PM »
You might want to buy/borrow/use a GPS to compare actual speed to indicated speed.  From what I've read on here these things are famous for being a bit slower than they indicate from the factory.  I've heard several comments about 235's and 30's making speedos indicate correctly.  I'm inclined to beleive this theory because with the stock gears and 31's my Tracker still didn't indicate what you'd think from the difference between 31's and 205's.
Offline derekj
  • 784
  • i'm the canadian guy eh?
Re: speedo reading
« Reply #2 on: March 11, 2006, 06:09:11 PM »
my 91 with the winter tires (235's) reads correct speed according to my gps. i have not driven it with my 31's and the gps yet so i don't know how much of a difference there is.
derek
91 Sidekick jx
2" BDS supension lift
2" BDS body lift
1" Coil spacers
Offline Vagabond
  • 95
Re: speedo reading
« Reply #3 on: March 13, 2006, 12:04:58 AM »
Use this calculator to find your speed with different tires:
http://www.izook.com/gearcalc.htm
[/url]
Shilly
Re: speedo reading
« Reply #4 on: March 13, 2006, 03:46:46 PM »
I run 30's on mine and it's dead-on accurate; knowledge gained thanks to one of the local jurisdictions who have those radar carts along the side of the road.   ;D
Offline urbanwheeler
  • 696
Re: speedo reading
« Reply #5 on: March 14, 2006, 12:31:03 AM »
mine has 215/75r15 tires on it, and its speedometer is exactly in sync with the vehicles actual speed. BTW, what kind of gps do you recommend getting. My friend has the Magellan Map330, and I noticed that ZW had an article about how they recommended it, but magellan stopped making it, and I dont know which one took its place. I can find them on ebay, but I dont want to take the chance of buying a non working one.
