So The Turbo Kick Is Running Again, But How Long Are ....
  • 17 Replies
  • 2952 Views
« on: March 10, 2006, 09:40:18 PM »
SO how long are my LTBs going to have that damn
flat spot in them ???  I've put about 30 miles on them
and still go bump bump   >:(
Well they have been sitting for 10 months with 8 PSI
in them, but are they doomed to have flat spots forever
Re: So The Turbo Kick Is Running Again, But How Long Are ....
« Reply #1 on: March 10, 2006, 11:27:31 PM »
The old trick with Bias tires is to move the rig a couple of inches about an hour befor you drive it, you might have to go to about three pounds and drive it and get them hot then air back up.
Offline zaggy
  • 1134
« Reply #2 on: March 11, 2006, 10:49:49 AM »
Good to hear it's up and running again Wild.......
Zag
« Reply #3 on: March 11, 2006, 12:01:02 PM »
Has it got the 16V in it now?
« Reply #4 on: March 11, 2006, 05:23:03 PM »
No, the 16V head is going on after
I fab up the new header, for now
I have it together in 8V form to get
it smog checked
Offline Yoak
  • 577
« Reply #5 on: March 11, 2006, 06:22:11 PM »
Do you pull the turbo pre-smog? Or do they even care?
« Reply #6 on: March 11, 2006, 07:05:11 PM »
I pull the pressure side loose, just in case,
but I can get it passed with the turbo installed
Offline ROSS
  • 1412
« Reply #7 on: March 11, 2006, 07:08:12 PM »
thought i was slow . arbs come next week.  about time you got her runnin. its only been a year
                                     Ross
Offline billybob
  • 23
« Reply #8 on: March 11, 2006, 07:37:02 PM »
Hey Wild... been thinkin' long & hard 'bout what you said bout turbos and am interested in how your build-up went... whether you're EFI or carbed and how did you manage the lean??
TIA,
billybob_ca
billybob_CA
« Reply #9 on: March 11, 2006, 10:18:32 PM »
OEM EFI + MegaSquirt EFI MPI injection system to
handle the fuel chores under boost.
http://wildcatent.freeyellow.com/zookmods
for a buildup and how I did the origional system.
I have had 3 failures of turbo manifolds, the current system
need to have a EGT sensor installed, Narrow Band O2 just
is not accurate enough to use in a turbo application, the reason
I melted a piston too  :(
« Reply #10 on: March 12, 2006, 11:07:04 AM »
Is the EGT for megawideband?
« Reply #11 on: March 12, 2006, 12:08:52 PM »
EGT doesn't interface with the MSII,
it's just a tuning aid for teh narrow
band O2, as it doesn't read well at
boost and at other than 14.7:1 AFR
« Reply #12 on: March 12, 2006, 02:40:10 PM »
so are you using to monitor the temperature of the narrowband sensor or for tuning?
« Reply #13 on: March 12, 2006, 06:34:55 PM »
Tuning, high EGT shows a lean condition,
and will help get the AFR to the right mix
for best power
« Reply #14 on: March 13, 2006, 04:16:07 AM »
Good to hear your back on the road again  8) So are you taking her to Moab this year?
