Rim Dillema
  • 1054 Views
Offline joe_and_jeep
  • Why have a Rev Limiter and not use it?
Rim Dillema
« on: March 06, 2006, 04:16:03 PM »
I picked up a set of 15X8 with about 3.75" or 4" backspacing.  I didn't measure.  Anyhoo.  There was some 31s on them.  I know changing the backspacing affects the scrub angle but now it steers wierd.  It seems like it is more difficult to come off center.  And when I hit a bump it seems like it pulls that side.  Didn't know if the backspacing changed the scrub angle and putting different leverage on the steering and just making it goofy.
I put the 31s on to see if they fit, they do.   But I just got a near new set of 235/75 BFGs.  The 31s are sorta bald.  Now is the rim too wide causing my steering issues?  It was fine with the stock wheels and tires.  Or maybe its a balance issue?
Should I put the new tires on the 15X8's or put them on the Stock wheels?  I'm checking tonight for loose/bent steering parts.
96 Tracker DD - 2in, 30s
95 Tracker Under the Knife - 4.3V6 - Rest Unknown
91 Jeep YJ Full Cage, Tri Link, D44/D44 35s
84 Jeep XJ Doubler HP44/9IN 35s
Re: Rim Dillema
« Reply #1 on: March 06, 2006, 10:29:45 PM »
It's the wheels, you will get used to it
Offline Vagabond
  • 95
Re: Rim Dillema
« Reply #2 on: March 06, 2006, 11:15:35 PM »
According to BFG, 8 in. is too wide for a 235/75.
[/url]
