Name this part, WE HAVE A WINNER!!!
  • 64 Replies
  • 9871 Views
Offline bandit86
  • 1641
  • elv8rguy
Re: Name this part, win a prize!!!!!
« Reply #15 on: March 01, 2006, 07:13:12 PM »
I bet if I had one of those, I could join a couple transfer cases together
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #16 on: March 01, 2006, 07:20:53 PM »
Then your a better man than I. ;)
Mike
« Reply #17 on: March 01, 2006, 07:24:31 PM »
Is it suspensin related?
We'll try the 20 questions approach.
'86 MJ, 2.5 AMC, 904, NP207
'85 GMC HD2500, 350, 33s
'84 Toy, 20R, fenders cut like an emo kid
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #18 on: March 01, 2006, 07:29:26 PM »
It is front suspension related. Thats all I can give.
Mike
Offline bandit86
  • 1641
  • elv8rguy
« Reply #19 on: March 01, 2006, 08:00:51 PM »
lower control arm (A arm) extension?
Offline Maroon Monsoon
  • 876
« Reply #20 on: March 01, 2006, 11:39:48 PM »
they already said that you douche.. go finish off your 350 by reving to 5k and holding it.. set off josh's car alarm again while your at it
just messing with you
Offline rockrat
  • 196
  • Got Ringr
« Reply #21 on: March 01, 2006, 11:46:30 PM »
Lower control arm for use with a spherical ball mount large hole, 2 holes are to locate the spring?
Offline Quaddawg
  • 1622
    • My Ebay Store
« Reply #22 on: March 02, 2006, 03:33:22 AM »
Front bearing support, for the weak side front axle
Offline hobgoblin
  • 224
« Reply #23 on: March 02, 2006, 05:49:37 AM »
I tried that already.....
Tom K.
Offline Shredder
  • 389
    • Me & My Rig
« Reply #24 on: March 02, 2006, 05:57:23 AM »
I was thinking that too but I think Mike is using that custom Calmini center diff in the makeover. I think that already has bearing support. Speaking of which I can't get Calmini to sell me one of those.   :'(
That part has me perplexed and I work alot with suspension design. That picture doesn't relate how big it is. I based size on the welds. Also is it complete or just part of a part? Hmmmm?
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #25 on: March 02, 2006, 07:26:40 AM »
Not real sure what that even is.  Kind of a solid axle guy that doesn't ask questions.
I think he said he was using stock sidekick knuckles...
The more I look at it the smaller I think it is than it looks - I'm thinking a steering brace for the idler arm, or steering box ......
Offline ZeusZuki
  • 411
« Reply #26 on: March 02, 2006, 08:02:30 AM »
From the looks of it, it has a tapered bearing in the end and attaches to a live component. There does not seem to be any pivot apart from that bearing.
I would guess that it is an upper arm that attaches to a pivot point on the chassis and then bolts up to a knuckle assembly - eg upper / lower arm arrangement 8)
Warm or cold?
ZuesZuki
« Reply #27 on: March 02, 2006, 08:23:31 AM »
I was thinking about that too, but the holes
look to be at different heights, but I can't
quite tell, I need another angle shot
Offline zaggy
  • 1134
« Reply #28 on: March 02, 2006, 08:56:15 AM »
Well after careful pondering and reviewing the threads.......
I would guess that it is the mount for etheir and upper control arm or the mount for the top of a coil over or custom strut set up.
Am I close?
Zag
Offline echojeff
  • 414
  • Lo que sea
« Reply #29 on: March 02, 2006, 09:13:21 AM »
some kind of strut brace and or mount?
95 Kick 4dr JLX.
