Front Brakes/Rotors-Newbie
  • 33 Replies
  • 4549 Views
Offline mojoincolorado
  • 95
Re: Front Brakes/Rotors-Newbie
« Reply #30 on: March 02, 2006, 02:23:54 PM »
If/when you replace the rear brakes (and swap out the axle -- it was cheap enough) Don't forget to lube any mounting bolts.  I had to grind off the nut plates on the trailing arms to frame as the bolt heads spun off.  Just an ounce (cc) of prevention here.
Offline ERock
  • 52
« Reply #31 on: March 02, 2006, 04:36:13 PM »
What kind of axle did you use in the swap?  I'm a real newbie at this thing.. or... I suppose I can look up a thread... I've discovered how awesome these things are just from hours of reading the forum archives...
thx
ERock
Temporarily Stock 96' Tracker 2dr 1.6 16V - 5spd Manual 4x4
  • 95
« Reply #32 on: March 03, 2006, 08:26:10 AM »
I bought a stock 98 axle at a junque yard.  Cheap ($150), has a boat load less miles, good brakes.  Make sure the r & p gearing is the same.  Get all the mounting parts with it, so you have spares.  Especially the top link (a-arm/ball joint device).  I've had a couple with problems (one froze up at the pivots that mount to the frame).
The axle is heavier than you think.  Bring a bud, or bring a dolly -- especially if she's cute!
Offline ERock
  • 52
« Reply #33 on: March 03, 2006, 02:58:17 PM »
Is the 98' different than the 96'
