My turbodiesel swap complete with pics
  • 18 Replies
  • 9422 Views
Offline mverley
  • 652
  • 20
  • SPACE JUNK
Re: My tubodiesel swap complete with pics
« Reply #15 on: June 11, 2006, 08:22:56 AM »
Thought I'd post a quick update; about a month ago my engine blew during a wheeling trip.  The #3 piston broke in half around the oil control ring and pretty much destroyed the bottom end.  I knew that cylinder was weak (see my original post), and based on the damage I saw when I removed it I believe it was unrealted to my other engine modifications.  That engine was pulled from a car that had been underwater every year for 9 years, sitting in a swamp.  Suprised it lasted that long.  Anyway, The rest of the engine looked quite good.  None of the other pistons showed any signs of melting, cracks, etc.  The valves and rest of the head were perfect as well.  I'm pretty sure that a stronger engine will hold up well to all of the mods.  I'm including some pics that show some more detail on how I placed all of the accessories and the turbo.
I finished rebuilding and installing a 1.6 hydraulic motor out of a 1992 Golf this weekend; bored .040", all new pistons, rings, bearings, rebuilt head, etc (see pics).  I'm running it at the stock fuel pump setting for the next few weeks, until the break-in is mostly done.  Even at the stock setting, this engine has as much power as my old one did when it was turned up.
My rig is a fusion of Jazz and Funk; I call it JUNK
« Reply #16 on: June 11, 2006, 12:12:14 PM »
And ya didn't rebuild it?
WOW, it held up perty well then.
Offline mverley
  • 652
  • 20
  • SPACE JUNK
« Reply #17 on: June 11, 2006, 01:12:11 PM »
Yep...it was in a farmer's field, covered in blackberry vines.  Every winter the car was completely submerged.   When I got it, all I did was use compressed air to pump some new fuel into the fuel pump, pull the injectors to pump the water out of the cylinders, remove the air cleaner, and she started right up.  I did have to replace the head gasket shorlty afterward, but that was the reason the car was there in the first place...
I didn't rebuild it because I didn't want to spend the $$ until I was sure the swap was going to work for me...the motor I have now was sitting on my engine stand ready to go in when my old one quit.  I knew it was going to happen sometime soon...
Offline Maroon Monsoon
  • 876
« Reply #18 on: June 11, 2006, 11:50:42 PM »
that is so cool that you did that swap, I want to diesel swap something.
