Tinkering with the sammi, 8V swap questions
  • 2195 Views
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
« on: March 03, 2005, 11:54:22 AM »
Well, I had some time tonight and the Tracker for once didn't need anything done to it right now, so I started messing with the seized sammi.
I pulled the plugs and shot some PB Blaster into the cylinders, then managed to break the crank free with a wrench on the crank pulley bolt. I made sure I had it free for a couple revolutions, then strapped in a new battery and tried the key. Mind you I bought this thing seized and had never heard it run. It turned over a few times, but wouldn't fire(yes, I had the plugs back in and wires hooked up the way they came off, LOL!). I tried again and hit the accelerator pedal a couple times and it tried to fire. It would stay like that, just on the edge of firing, but wouldn't catch without the starter... Then a clunk and it was stuck again, like it was seized up again, but when trying the key, I could feel the clunk in the gearshift. The smell of gas was in the air(coming from the exhaust) and a puddle of oil appeared and looks to have come from the area of the dust cover at the front of the tranny. My diagnosis? Dead, time to find a new engine! LOL!
If I swap in a 1.6L 8V tracker engine, will the 93 sammi's computer and harness run it, or do I need the computer and harness from the donor vehicle? I have seen that 8V swaps are supposed to be the easiest over the 16V swap, but I haven't been able to find out just how much of the donor vehicle I need... Any help would be greatly appreciated.
Lawdog, still have that engine and header? LOL!!!
Offline mesjr2004
  • 422
Re: Tinkering with the sammi, 8V swap questions
« Reply #1 on: March 03, 2005, 12:07:17 PM »
the tracker motor will work .just take the intake off the sammy and put it on the track motor. you will need a adapter plate for the swap though
Offline Digger
  • 1991
« Reply #2 on: March 03, 2005, 12:12:56 PM »
So I just need a Tracker 8V engine running my EFI sammi's intake, computer and harness, mounted up with an adapter plate, right? If that's it, that's not too hard...
Offline bioniconion
  • 268
« Reply #3 on: March 03, 2005, 01:16:44 PM »
digger u seen my tracker and u know what's going on with it..i wanna try to sell it..if u wanna come pick it up 350 and it's yours without the tires..that's the hawk header, exhaust, new alt, net starter, everything! and actually i have a fuel pump on the way too =\
Offline mesjr2004
  • 422
« Reply #4 on: March 03, 2005, 01:20:17 PM »
that should be it ,mite have to change the bistributer ,but i dont know
Offline ROSS
  • 1412
« Reply #5 on: March 03, 2005, 01:55:31 PM »
GO TO THE 1600 YOU WON'T BE SORRY.
THE POWER DIFFERENCE IS REALY NOTICABLE.
                                    ROSS
Offline jzap
  • 515
  • How difficult can it be?
« Reply #6 on: March 03, 2005, 01:55:37 PM »
Oh, 8v...  When I first read the subject line, I thought V8...
One I'd like to see in a Zuk is a 61thru 63 Buick 215 cubic inch aluminum block V8.  If there are any left around...
...never mind...
« Last Edit: March 03, 2005, 01:56:00 PM by jzap »
Jim Z.
66 Apache camper
Offline ROSS
  • 1412
« Reply #7 on: March 03, 2005, 01:58:40 PM »
LAST YEAR AT MOAB THERE WAS A GUY WITH A SMALL BLOCK OUT OF A CORVETTE IT SOUNDED REAL SWEET
                                                    ROSS
