The cheapo lift
  • 1841 Views
Offline TysonS
  • 383
  • www.funinbc.com
The cheapo lift
« on: February 02, 2006, 07:37:06 PM »
Hey guys,
I would just like some imput on the lift im building.
Front:
Stock Coil 2" Spacer
Stock Strut w/ 3.5" Spacer
**Possibly a 1" front diff drop if needed**
Rear:
Nissan 180sx Coils
1" spacer
3.5" Ball Joint Spacer
2wd Ford F-150 Shocks
Other:
31" Mud or Baby Boggers
4" Gas tank lift
3" Body Lift
I jus thought I would talk to you guys and see if you think there are any things a should add or change.  I'm going to be getting my L soon and am going to start putting my lift together.
***If you have anything that you think needs to be changed or added just post it**
Thanks A Lot Guys
-Tyson
« Last Edit: February 02, 2006, 08:21:19 PM by TysonS »
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
Re: The cheapo lift
« Reply #1 on: February 02, 2006, 08:14:57 PM »
With that kind of front lift you'll need more than just a 1" diff drop! I would say at least a 2" diff drop, otherwise your cv's wont be happy!
Offline TysonS
  • 383
  • www.funinbc.com
Re: The cheapo lift
« Reply #2 on: February 02, 2006, 08:22:07 PM »
Well, A 2" spacer should give me 3" of lift.    I will probably only do a 2" spacer in the front
Offline Digger
  • 1991
Re: The cheapo lift
« Reply #3 on: February 02, 2006, 08:32:11 PM »
On average, people installing my 1-1/2" spacers up front have been reporting a lift of 2-1/4". Also I know from personal experience with my own truck that this is as high as I would go without lowering the diff to match. In fact I think that this is even kind of high without any diff lowering because in a couple of different situations in the woods under full lock/full droop, the cv joint/cage thing has tried to pull apart on me...
Offline TysonS
  • 383
  • www.funinbc.com
Re: The cheapo lift
« Reply #4 on: February 02, 2006, 08:35:35 PM »
So, with a 2" coil spacer and a 1" diff drop i will be ok?
Offline Digger
  • 1991
Re: The cheapo lift
« Reply #5 on: February 02, 2006, 10:51:27 PM »
I am going to be putting a 1" diff drop into my truck that's running 1-1/2" front coil spacers, 4 door springs and OME struts. By adding 1/2" of coil spacer, you'll be adding around 3/4" of lift over what I have, so based on that I would lower the diff at least 1-1/2" total to go with your 3" lift...
Offline TysonS
  • 383
  • www.funinbc.com
Re: The cheapo lift
« Reply #6 on: February 02, 2006, 11:31:56 PM »
ok, thanks for the input, anyone else have any opinion?
Offline Uncivilized
  • 1469
    • Car Domain
Re: The cheapo lift
« Reply #7 on: February 03, 2006, 09:12:08 AM »
A 2" spacer is going to give you more than 3" - your looking about 3.5", I calculated my 1.75" spacers to give me 3", so I trimmed them to 1.25" to get exactly 2" lift in the front. I made a jig to figure it out, I was a little under, it was about 1/16 shy of 2".
Offline TysonS
  • 383
  • www.funinbc.com
Re: The cheapo lift
« Reply #8 on: February 03, 2006, 02:19:06 PM »
ok, thanks for the input.  Anyone else???
