Samurai T-Case in Sidekick/Tracker?
  • 3300 Views
Offline Shredder
  • 389
    • Me & My Rig
« on: January 28, 2006, 09:50:03 AM »
I am sorry I need to ask this but in my search I found no clear answer. So: Will a Samurai T-case swap into a Trackick? If so is it a "clean" swap or are there other changes that must be made? I hate being niave. Thanks.
Offline locjaw
  • 2045
  • 22
Re: Samurai T-Case in Sidekick/Tracker?
« Reply #1 on: January 28, 2006, 10:32:22 AM »
apples to oranges. sidekick= married t-case(case and tranny are direct bolt togeather). samuri= divorced t-case(has a driveshaft between tranny and case)
IMO if you are looking to lower your low ratio swaping in a 2 wd kick tranny and a sammy t-case would be the way to go(also reduces high range to account for larger tires)
if your trying to lower your high range then a R & P swap is gonna be a lot easier(no fabrication skills required)
hope that helps
jason
Offline Shredder
  • 389
    • Me & My Rig
« Reply #2 on: January 28, 2006, 01:27:10 PM »
Well that answers that. I guess it was just wishfull thinking that I could lower my high range and get super low gears all at the same time. That puts me back to looking for 5.38, 5.62 or 5.83s for the front and rear and buying the 4.24:1 low T-case gears. Oh well.  ::)
Offline Chief
  • 678
  • Whaddya lookin at??
« Reply #3 on: January 28, 2006, 02:47:12 PM »
OTT kicker 3. I swapped in a sammi case behind a 2wd tranny. For the money spent, I should have gone kicker 3. I can BARELY run on the highway!
Offline ed oorklep
  • 637
  • 1992 Suzuki Vitara
    • Suzuki Vitara 4x4
« Reply #4 on: January 30, 2006, 12:25:34 AM »
Hey chief, what tyre size are you running? As I'd like to do this swap with my 33"s  ;)
http://www.suzukivitara4x4.nl
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
Offline red_baron
  • 108
  • little red vit
    • surrey zuki society
« Reply #5 on: January 30, 2006, 05:49:11 AM »
I will be doing this swap to a mates truck on 18th feb.
Will take lots of pictures if you want.
Offline 1bigtracker
  • 3409
« Reply #6 on: January 30, 2006, 10:51:21 PM »
Offline ed oorklep
  • 637
    • Suzuki Vitara 4x4
« Reply #7 on: January 31, 2006, 02:52:55 PM »
u need this link
http://www.ottindustries.com/kicker3.htm
Stu
Isn't that like way too long in a swb? And way to expensive for me too, sending it from EU to US and back ;-).
Red Baron, please make loads of pic's and post 'm here  ;)
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
