wheel stud patern
  • 2027 Views
Offline wezzlegod
  • 227
  • under construction crowler
wheel stud patern
« on: March 04, 2005, 11:46:05 AM »
 ;D hay i was thinking of getting some used rimes for my sidekick and wanted to know if the bolt patern is compatible with any other car or truck. is it exclusive to trackicks? what years have different bolt patterns? thanks ;D ;D ;D ???
Offline 90Stomper
  • 427
Re: wheel stud patern
« Reply #1 on: March 04, 2005, 12:41:28 PM »
i dont know all the options, someone does and will post it im sure.  i do know that its a 5 x 5.5 pattern and jeep rims will work.
2004 chevy tracker, 4door, V6
says 'Chevy' on the outside,
Offline locjaw
  • 2045
  • 22
« Reply #2 on: March 04, 2005, 12:45:21 PM »
geo tracker wheels will work to ;D, just kiddin ya it is a 5 on 5.5 which was used on older j**ps and fords. you should be able to find something at the wrecking yard that will work for you. as for year all the trackkicks had the same bolt paterns.
jason
« Last Edit: March 04, 2005, 12:46:59 PM by locjaw »
Offline tracker8wr
  • 568
  • THE BIGGER THE BETTER
    • my home page
« Reply #3 on: March 04, 2005, 12:53:23 PM »
dodges 1500 also pre 93 but the ford rims center is to small to fit around the sidekick hub.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
Offline SnoFalls
  • 1358
« Reply #4 on: March 04, 2005, 01:52:06 PM »
Here's the interchange I figured during my hunt ...
5 on 5.5" bolt pattern interchange
46-86 Jeep CJ'S
85-01 Dodge Ram 1500 2WD
80-01 Dodge Ram 1500 4WD
02-04 Dodge Ram 1500 (New Body) 2/4WD
49-96 Ford 1/2 ton Pickups 2/4WD
66-96 Ford Full Size Bronco
86-94 Suzuki Samurai
89-98 Suzuki Sidekick
50-80 1/2 ton Scout I or II
lugnuts
12X1.25 for Suzuki vehicles
1/2 all others
(happy hunting ....)
Offline wezzlegod
  • 227
« Reply #5 on: March 05, 2005, 07:10:55 AM »
cool this will help a lot. ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
